I have a 95 T/A installing Gen 7 with the fasttrack kit..and the dual sync, i have the Accel Y cam/crank wire plug & play..
I am lost on what to do with the wires from the GEN 7 box, to the 8 pin Y plug (accel) and then with the wires coming out of the dual sync...
Any help would be great
thanks
If you are using the Accel dual sync distributor, you need the Dual Sync adapter harness part number 74101 (it maybe a 77101) which will connect to the distributor and direct to the Accel G7 ignition harness 8 pin connector. It then will be plug and play.
ok looked over it and ...the only thing is it shows the cam & crank as a 2 wire when mine is 3 ?...BUT it shows red and black, the 3rd is a clear wire..matbe that is a sheild ?
You should check where the wires come into the DFI box itself. The middle wire should be the unused sheild
The crank signals should be the white, black, and purple.
The cam signals should be black and white.
There should be two blank wires on the 8pin connector.
The orange wire on the crank was not use, just shielding I guess. I've got it setup on my car with the fast track harness and dual sync. If you have any specific questions I can get the exact pin outs for you if you need them.
Cavity
C & G - Ground
D - orange crank to purple
E - black cam wire
F - white cam wire
H - crank white to white
Cavity
C & G - Ground
E - black cam wire
F - white cam wire
Thank you thank you......yes if you could get me the pin outs on the 8 pin and if you could where they go at the Gen 7 box .. that would be great....
the wires i have for cam and crank (fast track)
orange - i don't think this is anything for cam & crank, will have to ck
white cam & crank +
black cam & crank -
open wire sheild ?
Dist
A - Pink wire goes to Ignition voltage(power on key)
B - Blank
C - Black Crank wire - B3 on DFI
D - Purple Crank wire - A3 on DFI
E - Black Cam wire - D3 on DFI
F - White Cam wire - C3 on DFI
G - Black Crank wire - B3 on DFI (spliced together with C)
H - White Crank wire - J2 on DFI
NOTE TO SELF: When in the calmap software if you hit Ctrl + F1 you will bring up a wiring schematic of just about anything. It defaults to the wiring harness, but has a pull down menu for everything you could need.
