I am helping diagnosis a 88 l98 for my father in law and we are receiving the following codes:
Code 13 - O2
Code 34 - mass air sensor low
Code 36 Runoff diagnostic malfunction
Are any of the codes related to each other. I have checked the Mass air sensor and it seems to functioning properly so I am confused. why a 34 would occur. Also what is the code 36?
Code 36 = MAF burn off malfunction. When you shut your car off, it energizes the MAF for about a second by heating up the wire for a split second. This is to clean the wire of any contaminants. If the ECM requests this and it does not happen, the ECM will throw a code 36.
