Power window motor replacment
Old Mar 19, 2006 | 03:05 PM
chb88's Avatar
chb88
Default Power window motor replacment
Hi all
I searched the threads and found how to get the old motor out of the door. Now that I have the window regulator on the bench it looks simple to drill out the rivets to replace the motor. Question: what have you all used to secure the new motor to the regulator? There is next to no clearance under the regulator gear. I'm thinking flat head machine screws. Thoughts appreciated.
Old Mar 20, 2006 | 02:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Can you rivet it from the backside, or use those double sided rivets?
Old Mar 20, 2006 | 09:48 AM
tequilaboy's Avatar
tequilaboy
I got some new rivets from a chevy dealer for free.
I didn't have a rivet tool big enough to pull through, so I just knocked the centers out and peened the rivets over using a punch and ball peen hammer.
Old Mar 20, 2006 | 11:16 AM
Jerris's Avatar
Jerris
Use rivits to reinstall it. If you use screws be sure to use a locking nut so that it does not vibrate loose.
Old Mar 20, 2006 | 05:24 PM
Phantom90's Avatar
Phantom90
When I had my window regulator out I took it to a chevy dealership and they let me go back into the working area and I paid a tech $20 to take the old rivets out and replace them with the thicker rivets which I did not have.
Whatever you do make sure the screws or rivets holding the motor onto the regulator are very strong... they have to be able to withstand the torque of the motor acouple thousand times a year
To Power window motor replacment
