heater core leaking?? help Mr. Wizard
Old Mar 20, 2006 | 10:28 AM
kmoudy's Avatar
kmoudy
Default heater core leaking?? help Mr. Wizard
ok..i started smelling this antifreeze smell...checked under the carpet on the passenger's side..and it was all wet...it's leaking bad...so..i went where any respectable corvette guy would go..walmart...and bought some stop leak...2 kinds....used one...drove around......flushed the radiator out....then added the other ...drove around...still leaks..i'm not much of a mechanic...any other tricks...guy at the fixit shop says about 5 to 600 hundred to fix...ouch.....
Old Mar 20, 2006 | 01:07 PM
Morley's Avatar
Morley
If leakstop stops a heater core from leakig it just means you completely plugged up the heater core.
Either A. come off the money to get it done..or B. do it yourself.
Old Mar 21, 2006 | 09:32 AM
rick lambert's Avatar
rick lambert
Or C, for now, block off the heater until you 1. either have time to fix it. Or 2, have the extra $$ to have it fixed. Lots of guys say they started with a heater core in our vettes and the built around them. From what I've read you have to be a contorsionist, and it's best to remove the passenger seat to get at it. OH, and with Morley, if stop leak stops the leak your whole system is going to be gummed up.
Old Mar 25, 2006 | 07:32 PM
weelanddeal's Avatar
weelanddeal
St. Jude Donor '05
i would not ever put stop leak in my car, you need to either bypass the heater core for now until you have the funds to do it or buy the part and do it yourself. bypassing the heater core is an easy thing to do if you need to drive the car, but of course you will have no heat. goodluck
To heater core leaking?? help Mr. Wizard
