distributor wiring
Old Mar 20, 2006 | 11:17 AM
dirtnapp's Avatar
dirtnapp
Default distributor wiring
I am currently doing an LT1 intake conversion and am having some difficulty with the wiring for the distributor. I am converting to a small style distributor. I cant seem to find any wiring diagrams on it. I need to convert the existing wiring to accomodate the new distributor.Anyone know where I can get this information, or better yet, have this information? I know that accel sells a kit for this conversion but I would rather just do it myself.
Old Mar 20, 2006 | 04:44 PM
redrose's Avatar
redrose
just match the colors
Old Mar 20, 2006 | 07:13 PM
johnnyevans's Avatar
johnnyevans
You can use most any connector (4 wire) to do the change over. you'll sometimes end of with an odd color wire, hook em up, usually the pulse wire. Solder and use heat shrink.
Cut the connector from your distributor, leave enough wire on it to make your connections, and use the plug from the small distributor.
V6, v8 makes no difference.
To distributor wiring
