Yes, Curtis you are correct. Another interesting fact for you too - the "new-style" vented opti actually debuted on the '94 B- and D-bodies (Caprice, Roadmaster, Fleetwood, etc.) but didn't make it's way onto the F- and Y-bodies until 1995. -Jeff
I know this is getting off the subject a bit but you may be the one to know. I had a 1987 Cavalier Z24 when I was in high school. I remember it also had some kind of "distributorless" system but I don't remember the details. Would you happen to know what kind of system was on this car? It seemed to work great and never gave me any problems in all of the years I owned the car.
Thanks,
Ok, 92-94 used the same opti-crap right?
[Modified by Glock'94, 11:33 AM 8/15/2001]
1987 Cavalier would have a delco DIS system. triggered by a magnetic crank sensor and powered by 3 delco dis coils. yes it is a hightly reliable system. Like everything else, the ignition module does go bad after a long while. and the coil goes bad even less. as long as plugs and wires are at their specs during the service life. it also has safety like automatic shutoff if oil pressure drops. bypassing the computer.
1987 would be the first year they put that in the 2.8MFI, 2.5FI, 2.2FI, 3.8MFI, 4.3MFI. Wonderful system. minimal maintance. The same system they are still using.... and they couldn't come up with anything better.
AlexS summed it up nicely. The newer systems even use more precise control and sensoring. The OBD2 cars can often detect which cylinder is misfiring or detonating utilizing sensors from the ignition system such as the crank and cam position sensor. Pretty amazing what cars actual do now. For example, many of the cars are programmed to back the timing down before an automatic trans gear upshift and raise it back up after the shift is complete in order to smooth out the shift. Unbelievable how far they've come! -Jeff
Why didn't this system ever get put on the Corvette?
They did, sorta...on the LS1 :( A similar system anyways, with eight individual coils. It's great, no moving parts.
My parents have had a few GM V6 sedans with the DIS system described above. Never a problem except for one day when I was driving and threw a belt, and somehow that cracked the ignition module.
