Well it seems that my right front wheel bearing is in need of a replacement finally. Unfortunately it seems that 2 great sources for the bearings no longer have a listing for them. I checked both Pep Boys and Napa since they were known to carry the Chicago Rawhide/SKF bearings. Well they no longer even have a listing for the corvette front bearings/hub. Any suggestions on where to get a quality bearing now? I don't think any of us have time for the overseas made garbage, it's not worth the chance. Open to suggestions.
Just checked that www.wheelbearingsinc.com site and they have no listing for the fronts either. Not sure what is going on here. I hope this isn't an item I may have to stock up on if they are getting hard to come by? Strange at the least.
Jim, have you tried the Timkens before? I really don't want to be the experimental guy on this one. I beat my car way to hard for that job.
Lee
They're on there now
As someone else mentioned, the '94 Firebird bearings can be used. Cost is $109 for those vs $189 for the Corvette units. I have the Firebird bearings. Externally they look slightly different, but other than needing to drill out 4 holes they bolt in and function perfectly.
Here's what the two look like side-by-side (the circled holes are the ones that need to be drilled to match the Corvette hubs):
Hoosier R-compound tires and road courses...I'd say I use my car pretty hard too ...
I used the front bearing from a 94 Firebird. Wire harness fit and all. I got this suggestion from the forum and it worked, 1/2 the cost of a corvette bearing. Good luck. Rick
I talked with my buddy who own's a NAPA store. The fronts are no longer being made. GM and their never ending quest to own the world has made licensing and or patents unavailable for repro units.
Our only source as of this time are the cheap knockoffs or OEM.
Apparently GM wants a certain quality built into the part(who could blame them) and the Chinese repros don't follow the GM standard which is why they are cheaper.
I bit the bullet and put ACDelcos from zip on mine, I figured that the original ones lasted for 175k miles, so I probably wont have to replace them again any time soon... they went on with no problem, no drilling, etc... that is one part that I wouldnt want to fail while on the road!
