Ways to increase your 60ft.
Old Mar 21, 2006 | 09:52 PM
Sinister87's Avatar
Sinister87
Default Ways to increase your 60ft.
Was wondering, what ways have you guys and gals managed to increase your 60ft times? What has worked for you, what are your suspension setup's and what kind of 60ft times are you seeing with your engine setup's? Thanks in advance.
Old Mar 21, 2006 | 10:18 PM
HvyHitr's Avatar
HvyHitr
Old Mar 21, 2006 | 10:23 PM
Pete K's Avatar
Pete K
I have a hard time hooking up the drag radials. Stock rear suspension with a 26mm stabilizer bar, drag radials, full tank of fuel, spare and jack installed and a 100 pound tool bag in the rear compartment help get it hooked up. Best 60 on a drag radial was 1.505. Average 60' is 1.620.
Old Mar 21, 2006 | 10:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
89 A4, basically stock, 2.0 60'
Warm the street tires up a bit, 28 lbs or so. Footbrake it to 900-1000 (anymore it pushes through the lights), nail it on the last amber. This is on cheapie Falkens fwiw.
Old Mar 21, 2006 | 10:28 PM
crossfire7's Avatar
crossfire7
Originally Posted by Sinister87
Was wondering, what ways have you guys and gals managed to increase your 60ft times? advance.
Decrease right
Old Mar 21, 2006 | 10:42 PM
Sinister87's Avatar
Sinister87
I'll agree to agree we are both right, increase as far as to improve apound(as in quicker) and to decrease(as in time) it's all in the wording I guess.
Old Mar 21, 2006 | 10:49 PM
kopbet89c4's Avatar
kopbet89c4
Damn, I do what cuisinartvette does, but I set the tire pressure on my cheap skinny 255/50/16 Falkens at 24 psi. Semi consistent 2.0s and a 1.9 on a good day.
Old Mar 21, 2006 | 11:05 PM
stormin310's Avatar
stormin310
I put a toggle switch on my rev-limiter so i can power-shift at 6500.....only 5 bucks wha ha ha....
Old Mar 21, 2006 | 11:09 PM
Sinister87's Avatar
Sinister87
Yeah, yeah I here yah! That damn toggle switch works, I'm telling yah.
Old Mar 21, 2006 | 11:23 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
275/50R15 BFG drag radials at 22 psi hot.
Stock rear suspension, stock front suspension, front swaybar removed, 15 x 3.5 wheels up front, no spare tire or carrier, full tank of gas, race weight of 3480, 1500 rpm launch on a 2800 stall converter with 3.45 gears nets a best of 1.67, average of 1.71
Old Mar 21, 2006 | 11:29 PM
severe-1's Avatar
severe-1
I found that "pushing" the pedal to the floor rather than just nailing it yeilded 1.8 60ft times with sumo's street radials, 30lb air, half tank fuel,
spare and jack, 86 auto 383
Old Mar 21, 2006 | 11:57 PM
hippy's Avatar
hippy
[QUOTE=kopbet89c4]Damn, I do what cuisinartvette does,
QUOTE]
Are you two related?
Old Mar 22, 2006 | 12:08 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I improved it by getting my credit card out. Bought some Mickey Thompson drag radials and shorter gears. No track report yet.
Best on Yokohama street tires is 2.05 at 20 psi, they never prep the track though. Quick clutch dump to clean them off. Drop clutch from 2200 rpms.
Old Mar 22, 2006 | 12:20 AM
rodj's Avatar
rodj
" I set the tire pressure on my cheap skinny 255/50/16 Falkens at 24 psi. Semi consistent 2.0s and a 1.9 on a good day"
Have had better results ,1.84s on same tyre @32psi.
Only a little spin to dry them off (can't drive around water at track), big burnout seems to glaze them up and they spin off the line.Others have had similar results running them hard.Go figure
Old Mar 22, 2006 | 12:57 AM
cv67's Avatar
cv67
St. Jude Donor '05
[QUOTE=hippy]
QUOTE]
No, but he'll go blind soon enough too.
Old Mar 22, 2006 | 01:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Better let me bed those tires in for ya, this is a highly skilled job and requires extreme concentration. Drop them off where I store the Z.
Just thinking of your safety here.
Old Mar 22, 2006 | 01:13 AM
Sinister87's Avatar
Sinister87
Hey Mojo, those d/r help ehh, much respect, nice driving
To Ways to increase your 60ft.
Old Mar 22, 2006 | 01:19 AM
Sinister87's Avatar
Sinister87
Pete, 1.505 on d/r DAMN, nice driving and torque
Old Mar 22, 2006 | 01:50 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
At times if you stage out of the grove you can get a better launch.
I burn out through the lights and go just to the right of the grove or the left.
Old Mar 22, 2006 | 03:03 AM
CentralCoaster
No chit? What's the reasoning behind that? I've always tried to get lined up with the rubber, although its hard to see at night.
