Rear diff to batwing seal renew
Old Mar 21, 2006 | 10:59 PM
VtVette's Avatar
VtVette
Default Rear diff to batwing seal renew
The previous owner of my '85 had a shop swap out the D44 that was in the car with a D36 from his '88. I have no way of knowing if the shop renewed the gasket between the rear diff/batwing when they installed the D36. I have not driven the car yet (it is an intensive winter project). I will have the car on the lift in the next week or so and I have not even checked to see if there is fluid in the rear. I am assuming the rear end is dry and if so now would be the time to seal the rear diff.
So, what is the easiest way to seal the rear diff? Does the diff have to come out of the car?
thanks,
Old Mar 21, 2006 | 11:03 PM
Pete K's Avatar
Pete K
No gasket was used. Gm used black rtv in the early years and orange rtv on the later years. Unit must come out to properly seal it up.
Old Mar 22, 2006 | 12:28 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If they swapped in a d36, they swapped the entire unit in, and probably didn't even crack the case. The batwing is not interchangeable.
Old Mar 22, 2006 | 12:31 AM
VtVette's Avatar
VtVette
Central - I didn't even think of that but now that I read it you're absolutley right!! That must be what they did!
I'll give it a shot as is. If it doesn't leak (doesn't look like it was leaking) than I'm good to go.
thanks for the info!
Old Mar 22, 2006 | 12:57 AM
Demonic85's Avatar
Demonic85
So why would they swap OUT a D44 for a D36? That doesnt make much sense to me.
Old Mar 22, 2006 | 01:20 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Whatever rear needs sealer,DO buy the "right stuff "sealant made by permatex for the rear end seal.The regular RTV wont hold up very long.
Most napa,car quest and parts stores carry this stuff.I used it and will never go back to regular RTV.This stuff will last a very very long time.
Old Mar 22, 2006 | 01:51 AM
Demonic85's Avatar
Demonic85
I got some of that Permatex stuff on my hand about a week ago and its still there and I wash my hands several times a day. A new definition of long lasting stuff.
Old Mar 22, 2006 | 08:17 AM
redrose's Avatar
redrose
adapter plate for d36 batwing to d44 diff is available.
Old Mar 22, 2006 | 09:34 AM
aboatguy's Avatar
aboatguy
The "Right Stuff" seals great!
Mike
Old Mar 22, 2006 | 10:27 AM
VtVette's Avatar
VtVette
Thanks guys I got turned onto "the right stuff" a few years ago. It's all I use.
I person I bought the car from owns a 1988 with stock drivetrain. He bought the 1985 because it had a really beefed up engine and drivetrain (it was a drag car). He stripped the drivetrain out of the 1985 and swappped it into his 1988. He was left with a gutted 1985 shell and the stock drivetrain out of his 1988. The shop that was doing the work swapped the rear ends. I bought the 1985 car and the 1988 engine and drivetrain. That is how the 1985 ended up with a D36.
Old Mar 22, 2006 | 05:34 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Last year we had a Permatex service rep at the shop one day. He told me that The Right Stuff does indeed have a service life of several times longer than their best silicone. Their best silicone BTW, is the Ultra Gray. It contains ceramic particles making it the strongest and also holds up the best to gear oil. He said gear oil was the most reactive type of oil to any sealer, hence if it holds up best to it, it's the best for any type of oil. Ultra Black was their next most durable sealer, he said. Be forewarned though, he told me that anything put together with The Right Stuff may quite possibly have to have the seal cut through with a razor blade to get it apart later.
Old Mar 22, 2006 | 07:00 PM
blown87's Avatar
blown87
GA Events Coordinator
It does stick rather well.
Old Mar 22, 2006 | 07:58 PM
CentralCoaster
Luckily the diff has pry points on it. I had to really work at it to seperate it. Sticks very well, none of it peeled cleanly off the aluminum.
I'm looking forward to pulling my 4spd apart with the right stuff on it, that was hard enough when it was factory rtv.
Old Mar 22, 2006 | 11:12 PM
redrose's Avatar
redrose
[QUOTE=Corvette Kid NC] Their best silicone BTW, is the Ultra Gray.
did he mention the original super blue in comparison to gray and black?
Old Mar 22, 2006 | 11:32 PM
Corvette Kid
[QUOTE=redrose]
Yes, it is among the worst. Still marketed because it is popular and cheap to produce. He was very candid.
Old Mar 22, 2006 | 11:42 PM
redrose's Avatar
redrose
talk about dumb luck--i stopped using the blue because i don't like the color (no kidding)
thanx
To Rear diff to batwing seal renew
