If you could help me real quick...
Old Mar 23, 2006 | 06:44 PM
Performance nut's Avatar
Performance nut
Default If you could help me real quick...
Just finished cleaning the IAC and I am about to start the resetting of the IAC. Vader86's website goes through a long procedure, which I believe includes the TPS reset as well, but the factory manual says:
Depress accelerator pedal slightly
Start and run engine for five seconds
Turn ignition "off" for ten seconds
Restart engine and check for proper idle operation.
Uh, which one is it?
Old Mar 23, 2006 | 07:03 PM
bogus's Avatar
bogus
depends on the year.
if you have an L98, follow Vader's instructions.
If you have an LT1, follow the ones you entered.
Old Mar 23, 2006 | 07:09 PM
Performance nut
Cool, thanks.
Out of curiosity, what happens when it is done wrong?
Old Mar 23, 2006 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
Don't believe EVERYTHING you read on here. If your FSM (not a Haynes or Chilton's) gave you the instructions you cited above, go with them. I haven't looked, but I believe that Vader86's instructions are the same as yours, with added procedures, like setting the minimum air and the TPS. When in doubt, unless someone gives you a real good reason not to, don't second guess the FSM. No, it isn't flawless, but without a credible reason not to, you are better off sticking with it. Vader86's combination of operations are well suited to, and complement one another.
RACE ON!!!
To If you could help me real quick...
