[CA emissions]Need a hand
Old Mar 23, 2006 | 08:31 PM
Performance nut's Avatar
Performance nut
Default [CA emissions]Need a hand
Just got back from the smog shop. Damn am I glad I did a pre-inspection. My hydrocarbons are way high (20x more than it was two years ago when I bought it) and oxides of nitrogen were out of spec (15% higher than two years ago). CO was the same.
According to a web search, I found that high HC are due to misfire and that probable cause is wires/plugs. However, it does say that this would also cause CO to be high, which it isnt. Hmm.
Things that have happened in the last two years: did a complete fuel system cleaning, a PCMforless tune, and IAC cleaning. Just noticed that the timing back in '04 was 6 BTDC whereas the timing now is 9 BTDC. The numbers:
2 years ago:
Now:
I know the PCMforless guys hang out around here but I dont know their forum names. If you know them, can you direct them here? I am not positive that its the tune; however, the list of changes are short. I want to make sure it 100% cant be the tune before ripping my car apart and find nothing.
Also, if you guys have some ideas, please post them. Thanks in advance.
Old Mar 23, 2006 | 09:19 PM
kabnvtt's Avatar
kabnvtt
Does the car not have any cats? Man thats a huge change.On my 87 I ran it through a pre check before I put my main cat on, the pre cats are gutted, and it was about like yours. I put the main cat back on (OEM) and it blew as clean as could be.Oops just took a look at your profile, was the car set up the same way in 04?
Old Mar 23, 2006 | 09:25 PM
Insane1's Avatar
Insane1
Whay does it say modified on other emmisions relaed equiptment?
Old Mar 23, 2006 | 09:29 PM
Performance nut
kabnvtt: Same setup, the only changes were those listed above. Just noticed the timing difference; however, I seriously doubt that would cause all this trouble.
Insane1: The headers, which were covered by an EO number in 2004 but due to a change, it is no longer listed. I plan to fight this; however, I have no leg to stand on until I can get the numbers back into spec.
Old Mar 23, 2006 | 09:35 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Hi,
we do not do anything that would adversly effect emmissions. Looks like its time for a full tune up.
Old Mar 23, 2006 | 09:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Retard the timing back, it helps, but won't get you there.
I'd replace the ignition parts, toss in a clean air filter, and put some dry gas in a low tank just before smog.
What's that "MODIFIED" in the smog item list? What does that mean exactly?
Old Mar 23, 2006 | 09:56 PM
Performance nut
Modified=headers which were covered by EO # when I bought it but are no longer covered due to change in EO.
Alvin, glad to hear it. I doubted it since we discussed this when I ordered my chip. Had to make sure though. Thanks.
From what I understand, high HC's mean unburnt fuel. Is this the right train of thought?
Old Mar 23, 2006 | 11:39 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
yes, usually high HC's and low CO is a misfire. I would go back and put new plugs, cap/rotor/ wires on the car. It could probally stand to have a fresh tune up anyway.
Old Mar 23, 2006 | 11:46 PM
bogus's Avatar
bogus
I am on the fresh tune idea...
new plugs/wires could go a long way to fixing this.
make sure the engine is fully warmed up, too.
take a rubber mallet to the cats... if you hear **** rattling, then you have a cat problem.
check for codes... never know what is lurking in there.
Old Mar 23, 2006 | 11:47 PM
Performance nut
Cool. I will buy the stuff tomorrow and give it a shot. Other than the tune up and retarding the timing back to 6 BTDC, anything else I should check before I take it to get rechecked?
How about the high NOx? I read a post about checking the EGR side of things for leaks. Any other suggestions/possible causes?
Old Mar 23, 2006 | 11:48 PM
bogus's Avatar
bogus
those are great things to start with.
Also, when you take it, run the snot out of it first. Be sure the engine is fully up to op temps.
Old Mar 23, 2006 | 11:53 PM
Performance nut
Yeah, no codes. I checked that when I was diagnosising the erratic idle problem I had (which led to the IAC cleaning). I let the car idle for 5-10 minutes this afternoon to make sure the erratic idle problem was gone. That and the drive to the smog shop, the engine was running for 10-15 minutes (<3500rpm).
As for the mallet, I will give it a shot. Though, I might be tempted to misuse the mallet if it fails again.
Old Mar 23, 2006 | 11:57 PM
Performance nut
BTW, since I am doing the tune up, does the type of plug have any difference what so ever on emissions (cheap plugs vs. platinum vs. +4 platinum vs. iridium)?
Old Mar 24, 2006 | 12:14 AM
sami85L98's Avatar
sami85L98
Iam with alvin, before modding my car i failed GA emmission than i did full tune up plugs, wire, oil change, cap & rotor along with new coil n distributor module, passed emmission like pulling hair from a hot cheese...u need tune my friend with AC delco stock stuff no need of MSD or accel.....heck my car passes emmission even with cam/head/LT headers with Alvin's tune...
Old Mar 24, 2006 | 09:20 AM
blown87's Avatar
blown87
GA Events Coordinator
From looking at your #'s i would agree that i would start with a good tune up first, and like "sami85l98" said do a oil change, this is something that a lot of people overlook when trying to repair a emm problem.
You might want to look at the "swing" on your O2's and make sure they are switching back and forth like they should.
With #'s like you have, if it is not your tune i would check your cat and make sure it is lighting off, ie hotter in the back than it is in the front.
Greg N
Old Mar 24, 2006 | 10:33 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Lose the PCMforless tune.
Try again.
Larry
code5coupe
Old Mar 24, 2006 | 05:17 PM
Performance nut
Greg N
How do I check the "swing" on my O2 sensors? I am not sure what you are referring to.
To [CA emissions]Need a hand
Old Mar 26, 2006 | 03:42 PM
blown87's Avatar
blown87
The O2 sensors can be checked by using a digital voltmeter, you are looking for a fairly rapid voltage change between about .300 mv to about .800 mv.
The best way to do this is with a scan tool, IMHO.
Old Mar 26, 2006 | 05:01 PM
GKK's Avatar
GKK
I had a "91" Camaro which passed Ca smog with flying colors the year I bought it, then two years later after I installed an SLP y-pipe, random-tech cat and flowmaster exhaust, the engine failed the smog test with high HC and Nox.
I took my Camaro to a very knowledgable mechanic and he said the engine had a lack of backpressure which the EGR needed to function correctly and it also, had a lean misfire. I finally had a stock cat installed, increased the fuel pressure and retarded the timing 3 degrees to finally barely pass ($600 later).
I vowed then to leave all parts from the Cat forward, stock. California emissions testing is rough.
Old Mar 26, 2006 | 09:33 PM
HiRiser's Avatar
HiRiser
put in a new ox sensor, it can't be working if you are running that rich, unless some other mod is just dumping in the gas
