58mm Naysayers.
Old Mar 24, 2006 | 08:01 PM
rodj's Avatar
rodj
Default 58mm Naysayers.
Having been here for 6 years are very familiar with opinions as to 58 TB usage on 350.Loss of drivability , bottom end torque , car will rust , etc.
Had track day and decided to test 58mm BBK intended for my race 383.
'87 with 95K 350 TPI / ZZ4 cam /siamized base / headers /3.07 /MT ETs
18+ runs with stock TB
Change to 58mmTB , no changes to engine ,TPS preset.
12 runs with 58mm
Exactly the same times both ET and 60 ft.No flat spot , SOTP felt better off the line with 58mm.
2 13.2s with each , balance 13.3. all 1.86 -1.87 60ft on ET streets.(Has gone 13.103 in cooler temps/ low humidity)
While this is obviously not a recommendation to run a 58mm on a 350, it shows that the negative effects of such are not as bad as claimed.
Even got same fuel economy (indicated ) on drive home with 58mm.
Only side effect is loss of very low part throttle reponse such as creeping foward in traffic from a stop.1/4 or more throttle and no difference.
Update.
As of 5-31-06 ,same 58mm combo as above (hood had not been opened between race meetings)
in cooler air ran 13.0XX all day with three 12.98X -1.78 60fts.
None of the claimed LOSS of bottom end torque here.
Old Mar 24, 2006 | 08:24 PM
Ramanstud's Avatar
Ramanstud
I wonder if a larger displacement (383ci and up) with a larger demand for air would show modest gains with the larger TB?
Good test though!
Do you know if you leaned out at all under WOT with the larger TB?
Old Mar 24, 2006 | 08:33 PM
TA's Avatar
TA
I wouldn't have thought there would be much difference, but unless you have the 383+ why spend $400 for NO gain.
Old Mar 24, 2006 | 08:42 PM
rodj's Avatar
rodj
I tried different fuel pressures on both setups (have AFPR) but can not say any was spot on given range of times ran.
Did run highest mph ,103 ( 101 -102 usually) with 58mm so would indicate top end working right.
Old Mar 24, 2006 | 08:49 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
A 58mm won't hurt you by any means. They are just not a good HP/$$ in most cases thats why i don't reccomend them often.
THe only thing to worry about is the TV cable will not be porportioned right with the new TB.. So with a small pedal movement, your getting the slack shift poing and the weak line pressure as opposed to the 48.
I perosnally have a monoblade on my 355 and that is one snappy biiiaaatch!! I don't even feel like I move the pedal, I just apply more pressure to it and it goes.
Old Mar 24, 2006 | 11:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thanks for the comparo! Good to see cold hard facts.
Old Mar 25, 2006 | 04:08 AM
Morley's Avatar
Morley
One limiting factor is that unless your plenum has been bored to 58mm, you effectively turned that 58mm TB into a 52MM, since the bores in the plenum are only 52mm from the factory.
Old Mar 26, 2006 | 01:46 AM
1996man's Avatar
1996man
This is an extremely good point. If you had on a stock size 48mm TB before then you probably would have seen better gains just going with a 52mm TB since it would be then matched to teh intake manifold opening. putting on a 58 is just going to make it even more turbulent and not gain any more power than a 52mm TB. most likely even less because the air will be more turbulent.
Old Mar 26, 2006 | 03:38 AM
nelson84's Avatar
nelson84
What if you have a superram with 58mm TB on a ZZ4? Would that work better than the regular tpi with the 58mm TB on a ZZ4?
Old Mar 26, 2006 | 06:24 AM
rodj's Avatar
rodj
FORGOT.
Plenum has been taken out to 58mm and area behind TB cleaned up .Are unsure of effects on 48mm setup (doubt it would be negative) as changed as same time as cam .
Test above was done only to prove / disprove claims of overly negative effects of 58mm on small stock type engines.
Old Mar 26, 2006 | 10:34 AM
1996man's Avatar
1996man
Originally Posted by rodj
FORGOT.
I agree with ur findings. I had a thought however that if you had an LTx type setup you might even see some benefit from the 58mm TB because those motors breath a bit better. just a thought.
Old Mar 26, 2006 | 12:18 PM
redrose's Avatar
redrose
i guess this also proves no positive going from a 48 to a 58 in this engine size.
thanks for sharing info..appreciate your effort
Old Mar 29, 2006 | 09:04 PM
pipe's Avatar
pipe
Hmmmm wonder how a Monoblade would work on my 383? Really wild solid roller and BIG ports on Brodix track 1s
Old Jun 22, 2006 | 11:10 PM
1996man's Avatar
1996man
we need someone to do this text with a 92-96 motor!
1996man's Avatar
1996man
we need someone to do this test with a 92-96 motor!
Old Jun 22, 2006 | 11:17 PM
Lichen's Avatar
Lichen
Like said, it depends on what your intake is ported to. It may also have something to do with the fact that you are in the southern hemishere where toilets flush backwards.
Old Jun 22, 2006 | 11:44 PM
LT4POWR's Avatar
LT4POWR
That's weird, my monoblade is super driveable, no snappyness or tip in issues. The only problem is sometimes (when hot) it randomly won't idle lower than approx. 1400 rpm.
I'm getting an Al flywheel installed tomorrow, so I'm a little worried about tip in driveability issues
I'll say a 58mm or a Mono, with those cubes and rpm.
To 58mm Naysayers.
Old Jun 22, 2006 | 11:55 PM
8388's Avatar
8388
St. Jude Donor '14
The engine is going to pull what it needs. Engines that require more will get more. Engines the don't need more won't notice a difference.
Old Jun 23, 2006 | 12:05 AM
Draven's Avatar
Draven
St. Jude Donor '14
Not without other supporting mods.
Old Jun 23, 2006 | 12:18 AM
ctoneil's Avatar
ctoneil
Cruising
Default 58mm
I have a 417 cu in, and the 58mm I run is a necessity. Personally, unless your running a 383+ there's no reason for it.
