Need some help
Old Mar 26, 2006 | 12:31 AM
L98Corvette's Avatar
L98Corvette
Default Need some help
Hi guys, hey i went out tonight to get in my 91 and it seemed like it had a dead battery, no click, no nothing. I put the charger on it, but the charger had a red light on it that said "check", i couldnt figure out why it wouldnt charge, so i disconnected both + and - battery cables and put bolts in their place and hooked the charger back up to them, now it is charging, can anyone tell me why this is happening? DO i have a short in the cables somewhere?
Old Mar 26, 2006 | 09:33 AM
Pete K's Avatar
Pete K
Hard to say. It could be anything. Charge battery and have it load tested. If good, check connections at battery and starter.
Old Mar 26, 2006 | 03:25 PM
L98Corvette
Hey thanks Pete. Do you know where the ground is off the battery to where it connects to the frame?
Old Mar 26, 2006 | 03:37 PM
blown87's Avatar
blown87
GA Events Coordinator
Sounds like you were not getting a good connection at the battery cables.
Old Mar 26, 2006 | 03:50 PM
L98Corvette
Blown, thats what i was thinking, do you think the cables are bad?
Old Mar 26, 2006 | 03:58 PM
rtracy's Avatar
rtracy
It won't charge the battery unless it is unhooked from the car. It's not just your car.
Old Mar 26, 2006 | 04:36 PM
Pete K's Avatar
Pete K
On my 87, the ground cable goes to the block next to the oil filter mount. There are many grounds there that also hook to it. Be sure that they are clean and tight. The large bolt will have a star washer between the cable and the block to give a good connection. Pull the bolt and sand everything clean and shiny if you have any doubt.
Old Mar 26, 2006 | 04:40 PM
vettefamily's Avatar
vettefamily
I had the same thing happen on my 90. I was about to change the cables then I found that they were just not tight at the connection on coil, just inside the drivers side fender. Hope this might help. I guess it's actually inside the drivers side Louver areanot sure what its called. Just follow the wires. It has been fine since then.
Old Mar 26, 2006 | 04:59 PM
blown87's Avatar
blown87
No, I think they were lose or had some corrosion on them or you just were not getting good contact to the cables with your charger.
Greg N
blown87's Avatar
blown87
You have got to be kidding, right?
To Need some help
