Brakes. Where Is It?
Old Mar 26, 2006 | 09:53 AM
BOTY79's Avatar
BOTY79
Default Brakes. Where Is It?
I HAVE HAD A HARD PEDAL ON MY 89 COUPE. I ASSUMED THAT IT WAS A BRAKE BOOSTER. WELL THAT WAS WRONG. SO ON FUTHER INVESTAGTION I FOUND THAT I AM GETTING NO PRESSURE TO THE PASSENGER SIDE FRONT BRAKE. THE OTHER THREE ARE FINE.I GET THE MANULE OUT AND I FIND THAT THERE IS A MODULATOR VALUE THAT DISTRUBTES TO THE DIFFERNT CORNERS. MY QUESTION IS THIS WHERE IS IT LOCATED.
Old Mar 26, 2006 | 10:47 AM
c4cruiser's Avatar
c4cruiser
The modulator valve is part of the ABS unit. Look in the compartment behind the driver's seat.
It could also be a restriction in the line or maybe a stuck piston in that caliper. If the fluid in the master cylinder reservoir looks dark, you should have the brake fluid flushed and replace with fresh fluid. If there is a restriction, that could clear it. A stuck or frozen caliper piston may require a replacement caliper.
And could you please not use all caps when typing?? That implies shouting. Thanx.
Old Mar 26, 2006 | 11:23 AM
BOTY79's Avatar
BOTY79
Sorrry. Did find it . Thanks.I have broke the line coming to that brake no pressure. Thats as far as i have gotten will check farther back. Oh i have pressure out of the master cylinder.
To Brakes. Where Is It?
