Does Krylon Fusion work like it says it does?
Old Mar 27, 2006 | 04:11 PM
C4CBF's Avatar
C4CBF
Default Does Krylon Fusion work like it says it does?
Converting my 86 to black and just replaced the carpet. I was going to see if this worked before i go and buy new trim plastic. Has anyone had any luck with spraying plastic trim with Krylon Fusion or something comparable? I am not very optimistic but its worth a shot. I want to use the funds elsewhere... like a full exhaust system
Old Mar 27, 2006 | 04:15 PM
Jerris's Avatar
Jerris
If you clean them up properly and use the primer they have for adhesion to plastic they will look good and last for a long time.
Old Mar 27, 2006 | 04:52 PM
86PACER's Avatar
86PACER
I used an adhesion promoter spray called "Bulldog". Then I shot the door panels, door sills, and other interior pieces with some Dupli Color flat black vinyl spray paint from the local parts store. It worked equally well on the carpet. I converted from a faded gray interior to a fresh dark black. For the plastic and vinyl peices, the key is to clean them off real good before painting and using an adhesion promoter. It really makes the paint stick. I used rubbing alcohol for the cleaning.
I figured I'd give it a shot before spending hundreds on a new interior. I was happy with the results.
Old Mar 27, 2006 | 05:02 PM
86PACER's Avatar
86PACER
Here's the before picture of the exact same interior minus the seats.
Old Mar 27, 2006 | 05:47 PM
WEH 2000C5's Avatar
WEH 2000C5
YOU SPRAYED THE CARPET WITH SPRAY PAINT! Please explain .
Old Mar 27, 2006 | 06:28 PM
C4CBF's Avatar
C4CBF
Where did you get the bulldog spray? Is Vinyl spray the same as the Krylon Fusion? I never really thought about the carpet but the trim looks great, especially since I am not building a show car. Yes! Now I can use the extra money for POWER!
Old Mar 27, 2006 | 06:33 PM
Draven's Avatar
Draven
St. Jude Donor '14
Did you do your seats with the same stuff? They look great!
I'm considering options as well. : )
Old Mar 27, 2006 | 06:37 PM
86PACER's Avatar
86PACER
It's a vinyl spray paint than can also be used to dye carpet.
Old Mar 27, 2006 | 06:38 PM
86PACER's Avatar
86PACER
The seats where re-apholstered.
Old Mar 27, 2006 | 06:45 PM
86PACER's Avatar
86PACER
I got the adhesion promoter spray at a local auto paint supply store. It might be under a different name in your place. I've never used Krylon fusion, but vinyl sprays work for your intended purpose. With the promoter, the paint really sticks. You could hardly scratch it off if you do it right.
Old Mar 27, 2006 | 07:41 PM
yellow dragon's Avatar
yellow dragon
the fusion paint wont crack if you flex the part you painted, ive painted dirtbike plastics with it and it hasn't cracked. very happy with the results!!
VtVette's Avatar
VtVette
SEM makes an excellent line of vinyl sprays, all in OEM colors.
Old Mar 27, 2006 | 09:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used Fusion to paint my pink top injectors black. 2 years and still black
To Does Krylon Fusion work like it says it does?
