90 wont start
Old Mar 27, 2006 | 06:10 PM
GordoC4's Avatar
GordoC4
Default 90 wont start
I had my 90 vette parked for the winter and this weekend decided to wake her up and get her ready, I had the battery on a trickle charge so it cranked and started up but soon sputtered and died. After several attempts to restart her failed I checked to see if I was getting gas to the fuel rails and it was bone dried. by the way I have a full tank of fuel, verified all the fuses to be good, and no codes. I'm not that good yet with the troubleshooting charts so If someone could steer me in the right direction It would be much appreciated
one more thing I don't get the srs light when I turn the key to on
Thanks,
V.
Old Mar 27, 2006 | 07:10 PM
Jerris's Avatar
Jerris
Check the fuel pump relay.
Old Mar 27, 2006 | 08:28 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
You're either not getting power to fuel pump or it's not running at all if the fuel rails are dry. You should hear it go "whrrrrrr" right when you turn the key forward.
Old Mar 27, 2006 | 09:05 PM
qws's Avatar
qws
Once you get the battery charged up again, turn the key on and see if you hear the pump turn on, if you don't check to relay (makes sure its getting a good connection) This happen with me just a few weeks ago.
Old Mar 27, 2006 | 09:22 PM
CFI-EFI's Avatar
CFI-EFI
It sat all winter and then started. The fuel system must all be functional. It sounds like it ran out of gas. I would start at the filter and check to see if there is fuel there. Then work your way foreword or backward, based on the results. Did you have any fuel stabilizer in the gasoline? How full was the tank?
RACE ON!!!
Old Mar 27, 2006 | 10:26 PM
GordoC4's Avatar
GordoC4
tank is full and I didn't add any stabilizer but before I tried to start the engine I put a bottle of dry gas in the tank
Old Mar 27, 2006 | 10:57 PM
skateparkdave
RACE ON!!!
I thought about the filter and bad gas and whatnot but if the pump is not working it can still run for a second on the fuel in the lines and rails by way of vacuum I guess. Or at least mine did. It started twice for a second with a bad pump. Then never again until I replaced the pump.
Old Mar 28, 2006 | 01:59 AM
steve1ph2's Avatar
steve1ph2
so you did check the sharder valve on the back passenger side of the fuel rail depress it if it squirts gas your getting fuel.
Old Mar 29, 2006 | 07:58 AM
GordoC4's Avatar
GordoC4
Thanks for the inputs guy's. I swapped the pump relay with a known working one and still no gas being pumped. Im definitly not getting 12v to the pump. Tonight I plan to troubleshoot some more. By the way does anyone know if the ECM sends the 12v to enable the pump?
Thanks,
V.
Old Mar 29, 2006 | 08:26 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does in my 86. Sends 12 volts to coil in fuel pump relay
Old Mar 29, 2006 | 08:29 AM
AGENT 86's Avatar
AGENT 86
Try applying 12 volts to terminal "G" on the ALDL connector. Pump should run continuous, if not, while the power is still at terminal "G", check the FP fuse to see if it's getting the power.
Old Mar 29, 2006 | 08:39 AM
RRT vette's Avatar
RRT vette
I just had a similar problem with my 86. These guys pointed me in the right direction. Try this, take the gas lid and rubber gas neck off so that you can see the tank. Run the hot wire to terminal "G" and use a light tester and check the tan (on my 86) to see it lights up. If it lights up then the FP is bad, if it doesn't light up then check the fuse to see if it lights up. On the relay harness I think the wire is green with black or white stripe and see if it lights up for 2 seconds while you turn the key on. I didn't have the FSM at this time and the Forum helped. The troubleshooting diagrams are hard to understand at first but study it a little and you will get it. My car sat up for 5 years and it had a bad relay and pump. Do a search in this forum for "86 fuel prob"
Old Apr 2, 2006 | 08:36 PM
GordoC4's Avatar
GordoC4
I finally got to work on my fuel problem and it turns out to be a bad fuel pump, It worked fine when I parked the car last October, but whatever I have the pump on order so I'll have to wait till next weekend to find out if I'm right.
Thanks,
V
Old Apr 3, 2006 | 05:28 AM
JYAMZE's Avatar
JYAMZE
not sure what kind of diagnoses you've applied...but try the old C4 guru's method and bang on the filler a few times to establixh good electrical connection...this of course will not help if you've determined that the fuel pump is definitely the problem.
Old Apr 3, 2006 | 09:49 AM
GordoC4's Avatar
GordoC4
Well I had the pump out of the tank and applied 12v's directly to it and get nothing as far as the motor working. I'm thinking this should turn the pump on if it was good. Would you guys agree???
V
Old Apr 3, 2006 | 10:02 AM
RRT vette's Avatar
RRT vette
V
I did this same test with mine and nothing. Replaced it and it's all good.
Old Apr 20, 2006 | 04:47 PM
GordoC4's Avatar
GordoC4
Thanks,
V.
Well finally got around to replacing the fuel pump and all is good she started right up, Thanks to all who gave great advice without it she still be in the garage.
Thanks, V.
To 90 wont start
