On-Board computer Error Code
Old Mar 27, 2006 | 09:22 PM
IrishJoker's Avatar
IrishJoker
Default On-Board computer Error Code
Drove the 95 to work this morning bacause if finally was a great sunny day here in Maryland. I noticed it was ideling a little rough and then the "Service Engine Soon" light came on in the DIC. Well I hooked it up to the diagnostic unit when I got home and it came back with an Error Code of "44" Left Bank Oxygen Sensor Lean. What the heck does that mean? Anybody got a clue. Last fall I installed a brand new Magna Flow Cat Back system and a new High flow Catalytic converter. I know the mechanic had to install a bong for the oxygen sensor for the catalytic converter, where is the left bank sensor located? Let me guess I gotta lift the car to find it, right?
Old Mar 27, 2006 | 11:08 PM
Jerris's Avatar
Jerris
In the left exhaust below the manifold. You can see it better from under the car, however do not change it as the O2 is likely not the problem, it is just the sensor that reports the problem to the ECM. You need to troubleshoot it and find out why it is throwing that code.
As CFI-EFI always says ....... Dont shoot the messenger.
Old Mar 28, 2006 | 07:22 AM
RRT vette's Avatar
RRT vette
This sort of problem happened to me. My 95 ran good one day and the next the check engine light came on and it idled rough. You could drive it but it would blow black smoke out of the left muffler when I gave it throttle. Checked it on a diagnostic tool and it said bad o2 sensor on the left. I replaced the O2 sensor just under the left exhaust manifold and it ran like a top. Mabe this will help ya.
Old Mar 28, 2006 | 07:48 AM
mseven's Avatar
mseven
I agree, you stated your mechanic installed a bung, are there any exhaust leaks? A scanner would help, there are other variables.
Old Mar 28, 2006 | 08:39 AM
IrishJoker's Avatar
IrishJoker
What do you suggest I check?
Old Mar 28, 2006 | 11:29 AM
IrishJoker's Avatar
IrishJoker
tttt
Old Mar 28, 2006 | 11:45 AM
Jerris's Avatar
Jerris
Pull the plugs on the left side and see if they are burning lean. Compare them with the ones from the right to see if there is a difference in the mixtures of the two banks.
If the left ones are indicating a lean condition, look for a vacium leak or exhaust leak on the left side of the engine and correct.
If they are the same as those on the right and not showing lean condition I suspect you have a bad O2 sensor.
Do this test first to see if there is indeed a lean condition on the left side of your engine and correct it if there is before simply changing the O2 sensor.
Hope this helps.
Old Apr 14, 2006 | 08:57 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
did you find your problem ?
Old Apr 17, 2006 | 02:28 PM
IrishJoker's Avatar
IrishJoker
Not yet - I moved the 95 out to the drive way and covered it during the winter while I was restoring my 81. I bought a brand new cover to protect it while it was parked . By the condition of that new cover, it appears some critter has been nawing on it. Holes everywhere. I suspect some squirrles decided my cover would make nice nest material. So I am wondering if they decided to naw on a few other things under the hood. I will begin a detailed check of the engine compartment, nawed vaccuum and wires this weekend. If I can't find anything a new oxygen sensor is about $59.00 at Advance Auto.
To On-Board computer Error Code
