1- I'm reading the instructions that came with the used super ram and it mentions the factory vacuum line to brake booster is replaced with supplied rubber vacuum line. Don't have !! Is tossing the factory line and replacing with rubber line a must ??
2-Want to replace intake base to head and intake base to runner bolts with stainless. I'll assume the allen head would be best. Anyone have a list of length/pitch etc of these two sets of bolts ??
You will need to buy some vacuum hose.. And the intake to head bolts will not work in some areas. Under the runner. You will need to use a low profile bolt in those areas.
