Keyed Power Source - Air Divertor
Old Mar 28, 2006 | 11:31 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Keyed Power Source - Air Divertor
I know I can use the fan relay, but since I removed the air divertor, could I use that as a keyed power source for my heated O2 sensor?
Thanks,
Joe
Old Mar 28, 2006 | 11:48 AM
Jerris's Avatar
Jerris
Thanks,
Joe
If you test it and it is indeed a key on source, by all means go ahead and use it. if you thing the fuse for this is too small then use it to trigger a relay for the heated O2 sensor.
Old Mar 28, 2006 | 11:56 AM
Ramanstud's Avatar
Ramanstud
I would try to find out what amperage that circuit is rated for (and what your heated O2 will draw), but in all likelyhood I think the O2 sensor will only need a 5 amp circuit which will be no big issue with the existing wiring. Just make sure the circuit you're using is keyed - but not switched by any dash controls or ECM functions (which might cause the heated circuit to be turned on or off randomly).
Personally, I'm a big fan of running a dedicated, keyed and fused line by use of a relay.
To Keyed Power Source - Air Divertor
