Difference between 3.45 vs 2.59 gears..
Old Mar 28, 2006 | 11:16 PM
MrNuke's Avatar
MrNuke
Default Difference between 3.45 vs 2.59 gears..
Well, we finished swapping my Dana44 with 3.45 gears into my '92 automatic which had 2.59s, and..............
DAYMNNN.......
Par throttle and throttle response is waaay better, she spins the rears from a stand stop and loses traction under 25mph with the ASR off, and loses traction going into 2nd gear at about 35mph..
Car itself is a LOT faster than it was with the 2.59's.. TGook it up to 120mph in a heartbeat.
A defenately RECOMMENDED upgrade for people who want better performance..
Old Mar 28, 2006 | 11:26 PM
aboatguy's Avatar
aboatguy
The beancounter that decided to saddle the LT1 with 2.59s did GM a huge disservice.
Mike
Old Mar 28, 2006 | 11:28 PM
redrose's Avatar
redrose
another kid gone bad...(now we'll show you the secret handshake)
Old Mar 28, 2006 | 11:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mike
Yes and no.
With the 2.59's it would accelerate quickley, you just didn't know it until you looked at the speedo, but with the 3.45's, you knew you were accelerating which brings up another interesting point.
My automatic with the 2.59's turned in the same 60' times as my six speed with the 3.45's. In the end, the six speed was quicker and faster(2 tenths and 5 mph), but with the 3.45's, the auto matched the mph of the six speed and bettered the ET by 5 tenths over the six speed.
Old Mar 29, 2006 | 02:31 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Mike
Sorry Mike but having been a manufacturing bean counter for the past 30 years I can guarantee you that it was some marketing bright-boy who dictated those kind of things.
Most of us bean counters are pretty wild guys
Old Mar 29, 2006 | 02:36 AM
hippy's Avatar
hippy
Are you saying you gained .7 seconds by going from 2.59 to 3.45 in the auto?
Old Mar 29, 2006 | 03:25 AM
DocSpeed's Avatar
DocSpeed
I gained a whooping 7mph going from a 2.59 to a 3.73 which is a little more gear. My ET when down though due to traction issues now. I have to run at the track with at least ET streets to even get any traction.
Old Mar 29, 2006 | 07:20 AM
Mr Mojo's Avatar
Mr Mojo
More like .9
Best with the 2.59 was 13.37, best with 3.45 was 12.50, so it's .87
Old Mar 29, 2006 | 07:28 AM
kalister1's Avatar
kalister1
The original gears are for gas mileage, not performance.
Old Mar 29, 2006 | 07:50 AM
SuperL98's Avatar
SuperL98
This might be interesting to some.
Sorry for the big pictures, but you need to be able to read them
The car is an 1988, ZZ4 crate engine, TPIS runners and manifold, Paxton blower about 7psi, stock manifolds and cat, magniflows out back.
Car is identical except for the change from the 2.59 to the 3.54.
The 2.59 run was in August 2004, gears changed over the winter, 3.54 runs done June 2005 year, so weather conditions close.
Only have data up to 140 for the 2.59.
2.59 axle 0 to 140 mph
2.59 axle quarter mile
3.54 axle 0 to 140 mph
3.54 axle quarter mile
So don't sell the 2.59's to short, unless your just doing quarter mile runs
Old Mar 29, 2006 | 09:29 AM
GlennS87's Avatar
GlennS87
Yes and no.
I would guess this is because 1st gear on the auto is so low.
Old Mar 29, 2006 | 03:32 PM
MTVette's Avatar
MTVette
When I swapped out the 2.59's for 3.54's in my '92 A4, my 60' times went from 2.1 to 1.9, and quarter mile times went from 13.85 to 13.17. No other changes. Gears rule!!
Old Mar 29, 2006 | 03:48 PM
MrNuke's Avatar
MrNuke
Took her for a long cruise today, and every on-ramp I just floored it with the asr off, left a pretty amount of smoke and a firm 1-2 shift that actually cut the tires lose.. Car is soo much fun, can't believe I haven't gotten an LT1 long time ago..
I'm going to try to go to etown next wed and get a baseline with a bone stock '92 with 3.45gears as the only mod..
Old Mar 29, 2006 | 04:06 PM
NEVRL8T's Avatar
NEVRL8T
How much did the 3.45's cost you?
Old Mar 29, 2006 | 04:31 PM
MrNuke's Avatar
MrNuke
I STOLE it for $330 when a dealership closed about 2.5years ago..
It was a BRAND NEW '95 Dana44 from GM sitting in the warehouse..
Usually these go for $2k+ new, about $1.5k used on ebay and here.
Old May 14, 2006 | 10:09 AM
khartford's Avatar
khartford
Yes and no.
Mr. Mojo,
Are you saying ( if I'm doing the math correctly) that you picked up 7 tenths? I currently running 3.07 in my 89 A4 Do you think 3.45 or 3.73 would help drop a few tenths?
Thanks for your assistance.
- Ken
Old May 14, 2006 | 12:22 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Ken, with your L98 you're not going to see the same results as an LT1. Your power band is at a lower rpm while the LT1 is further up. It seems most previous post about this point to a 3.33 - 3.45 for an auto L98 and 3.73 for the LT1 auto.
To Difference between 3.45 vs 2.59 gears..
Old May 14, 2006 | 01:34 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
That is awsome Nuke Im not so sure how long my D36 and 3.54's will last but I'll give it a try, as long as I dont drag it right??
Old May 14, 2006 | 03:03 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I have decided to upgrade my 3.07 D36 to 3.54. I dont plan on dragging, just some street fun and cruising. I shied away from the 3.73 in the D36 to conserve some semblance of decent gas mileage and also to not kill the D36 too soon. LOL. How do you like the 3.54 in the D36?
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Mike
I think it was likely someone more concerned with CAFE than cost.
