Wideband Software Inputs....Questions
Old Mar 28, 2006 | 11:34 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Wideband Software Inputs....Questions
I have an Altronics wideband that has rpm input and two 5 volt inputs. I will be using a 5 volt input to monitor TPS.
RPM input? Can i use the distributor reference pulse as a RPM input ??
I'm going to tie into the harness at the ECM so if i can get both inputs at the same location, all the better.
I'm all ears
Old Mar 29, 2006 | 08:32 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
I think so, as long as the unit / software is able to translate that reference pulse to crankshaft RPMs. Meaning (if I am understanding correctly) - for every 1 distributor reference pulse, the unit knows that the crankshaft has gone around 2 times, giving you the proper RPM data. (See my other thread in this section )
Old Mar 29, 2006 | 12:43 PM
rick lambert's Avatar
rick lambert
Not until you get that yellow Duralst sorry can't help, but there's a guy in the tech section-MAF problem that could sure use your help.Needs a trouble shooting diagram posted-and you're the man These guys here will definetly answer your question, bunch of knowlegeable nice guys-like u.
To Wideband Software Inputs....Questions
