Muffler Experts please educate me
Old Mar 29, 2006 | 04:50 PM
hz900's Avatar
hz900
Default Muffler Experts please educate me
I'm looking at Summit's website at mufflers to buy for my car and see a couple options that I don't know the difference between. Please explain the difference between the internal construction of Chambered and Turbo mufflers.
In particular how it pertains to HP and sound.
I don't want a glasspack sound/loudness but at the same time I don't want it stock quiet either.
Old Mar 29, 2006 | 05:19 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I think we could better answer your question if you indicate what year vette you're asking about. For example if it's a late model LT1 I don't believe that you're going to see and appreciable HP gain by just changing mufflers as the stock ones flow quite well.
Old Mar 29, 2006 | 05:37 PM
hz900's Avatar
hz900
Sorry. The model year matters not because as it is I have no exhaust system currently on the car.... I rebuilding it, so I need to buy something because the stock stuff no longer exists. But to answer your question its a '90 383 L98, and it will have true duals with an x-pipe. Looking at the Hooker and Dynomax mufflers, single inlet/outlet, and they have chambered or Turbo style, for close to the same price. I just don't know which to go with as I don't know the difference.
Old Mar 29, 2006 | 05:51 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I think the term Turbo is essentially meaningless today. When the Turbo mufflers first came out in the early sixties, they were a lightly-muffled unit that came stock on a turbocharged Corvair.
Today, everybody calls their muffler a Turbo. Don't worry about any distinction between what is called a Turbo and what is called a "chambered" muffler; take any non-straight-through muffler apart and it will have chambers. So, for all practical purposes, there is no difference.
By the way, I put the Hooker Aerochambers on my C4 and love them. The shape looks like it was designed for the C4...it fits perfectly. It is a fairly quiet muffler though, which is one reason I like it. Just a little more growl at low rpm than the stock units, and just a little more ring (reminds me of a jet engine) at high rpm. Oh, and they do resonate.
Larry
code5coupe
Old Mar 29, 2006 | 06:00 PM
RED92LT1's Avatar
RED92LT1
I have a 92LT1 and when I bought the car it had 3" Flowmaster mufflers installed. I don't know what series they were but it was annoyingly loud (resonance) inside the car at cruising speed. I switched to Hooker Aerochamer mufflers with an improvement in resonance but still annoying. Next were a set of Pacesetter resonator tips (no mufflers), sounds good, looks good but still have the resonance. However, I have purchased the FlowTech Afterburner mufflers from Summit (BIG-50322FLT) because they are a chambered (Free Flowing) muffler supposedly without the resonance. Can't tell you how they sound/work since they are still in the box, but the price is right at $39.95 and they are well constructed.
I would suggest that you do not weld the mufflers on, and carefully plan your exhaust system so if you want to change mufflers, for whatever reason, it's an easy task.
Hope this helps
Brian
Old Mar 29, 2006 | 08:55 PM
mseven's Avatar
mseven
I think the more cfm they flow the louder they will be. I think jegs site had some flow numbers of various mufflers. I have dynomax s.t.'s and they are reasonable. I don't think they they are the most performance muffler (as getting max power), but I wanted fairly quiet. I believe there will be some trade off. BTW mine is 3" true duals w/RT bullits and 'x', from the x it chambers down to 21/2" to the mufflers.
Old Mar 30, 2006 | 01:08 AM
goldeneye_vet's Avatar
goldeneye_vet
hz900 I have the true dual setup that you mention with the dynomax turbo mufflers and the sound is throaty. Sorry that's the best way to describe it. I have hedman headers and a muffler shop made x-pipe with true duals and I like the sound. When my car was stock with my L98 the resonance wasn't so bad but once I get my new alternator its off to see the man with the plan at the muffler shop to come up with something else to cut the resonance down. The wife loves the new 383 but she does NOT like the resonance. To keep her happy about all of the money I spent on my new 383 I think getting the exhaust note taken care of keeps me off of the long honey-do list that occasionaly pops up every now and then. Good luck picking out a combo that works for you!
Old Mar 30, 2006 | 10:59 AM
tequilaboy's Avatar
tequilaboy
As has been said, turbo mufflers are old corvair technology updated in the 80s, remember the cyclone sonic turbo. The best 80s muffler according to Hot Rod testing.
Look at dynomax 2 1/2" for example: super turbos flow 410 cfm
ultraflows flow 1133 cfm
I think the dynomax super turbo is actually the old sonic turbo design.
Note: even with the low flow numbers, the 2 super turbo's are adequate for around 375 hp. Two ultraflows: something like 1030 hp. I think they even outflow straight pipes, if you can trust the numbers.
Anyone out there with ultraflows? How do they sound?
Old Mar 30, 2006 | 11:44 AM
Gold1986Vette420's Avatar
Gold1986Vette420
Hope this helps
Brian
Looking for qiuet Power myself. Keep us posted.
Old Mar 30, 2006 | 11:55 AM
Bigredwing's Avatar
Bigredwing
My wife says that if you put the word Turbo on anything a man will buy it.
Old Mar 30, 2006 | 02:42 PM
RED92LT1's Avatar
RED92LT1
Makes perfect sence ... if you put "SALE" on any useless item women must have it.
Interestingly though ... I have more "sale items" in my house then stuff that has TURBO printed on it. Seems like there ought to be some sort of balance here.
Old Mar 30, 2006 | 03:08 PM
swifty's Avatar
swifty
Headline: "Sale on Turbo Stuff at Wally World" - I sense happiness all around.
Old Mar 30, 2006 | 04:12 PM
Bigredwing's Avatar
Bigredwing
To Muffler Experts please educate me
