LS1 engine power production VS L98 (deep tech within)
I sold my TA and bought a 1992 corvette with a 383. The 92 corvette made 380 RWHP NA, close to 500 on juice, and was an absolute joy to drive. I was always curious about the power though. Coming from the LS1 camp, a stroked engine with heads and cam making less than 400 RWHP is a joke. I kinda figured the 383 had some mis-matched parts, or some other problem that was preventing it from making the power it should. I sold that car, and bought the 1991 I have now.
When I had the LS1, the only thing that turned me off were the absolutely astonishing prices of mods. In 2000, a set of headers for an LS1 was ~$1500, a set of heads was easily upwards of 2k, etc... That's when my interest in the generic SBC really started to come around. Cheaper parts, and the same power potential as the LS1 once you started modding, or so I thought.
I can't count the number of head/cam/intake L98 cars I see on here making 310 RWHP, sometimes less. What's the deal?
LS1 heads, in stock trim flow ~255 with decent low lift numbers. Those heads routinely take 346 cubic inches to 400 RWHP.
Why when you put an equal flowing head on a conventional SBC, do they not make anywhere near the power? From what I have seen on here, you'll never approach 400 RWHP with a stock bottom end L98. Even after changing the heads/cam/intake.
LS1's have cathedral port heads, and they are a 15 degree head, but is that really where the power comes from? I figured 255 CFM of air would support the same amount of power regardless of how it entered the engine.
What's the deal?
I changed my mind after seeing LSx with slight mods dyno 325rwhp. I thought to myselve, What the hell! Here I am with good heads, a notbad cam, and a better flowing TPI that should make power all the way up to 5500 due to the cam, and the heads. I dont get it either!!
Reason I originally wanted this was, because I wanted to pop my hood, and the motor look close to stock as I could and run 12.4-12.7 range. Maybe this could be done, I truly dont know. I read about the problems guys have with head/cam/intake and the ****ty power they make, and it pisses me off.
What's the deal?
Reason I originally wanted this was, because I wanted to pop my hood, and the motor look close to stock as I could and run mid 12's.
If you think you can build a stroker L98 with forced induction in a C4 for 5k you're out of your mind. Just the supercharger kit will run you more than 5k by the time you add the fuel system and other supporting components.
I'm not trying to be an ******* here, but you don't really know what you're talking about. Posting just because you have nothing better to do, doesn't really contribute anything to this thread. It makes more difficult and time consuming for those who have some legit tech to add, and it forces other people like you, who are coming here seeking knowledge, to read through your useless ramblings about things you know nothing about.
I'm sure you're a good guy, and meant well; but sometimes discretion is the better part of valor. Just hang back and lurk if your interested, no need to muddle up the post with, "This is what I think I might have read somewhere else on the Internet, but I don't have any real knowledge of."
Like I said man, I'm not trying to be mean, but that is how I am going to come off. If we could keep this one close to 100% tech, that'd be awesome. Then, when it turns up in searches it'll be 100 times more helpful to other newbies.
When you start modding is where the real difference begins though, the port design on the LSx heads is really where the gains come from. A better angle for one, cathedral design, and better spacing so they have a MUCH straighter shot to the combustion chamber. That's why you can get 440+ RWHP out of a heads/cam LS1 and 460+RWHP out of a heads cam LS2.
The EASE that an LSx can suck in that 255 cfm requires less effort to bring in and expell than on an SBC.
The siamesed ports on the SBC heads were always that engines' achilles heel. No matter what you did, the engine would have to be so peaky and tempermental to generate the kinda power the LSx sees as a matter of course.
Remember, the LSx is a result of 50+ years of V8 engineering. It is the dream motor... can you imagine the amount of power the NASCAR guys could get if they could use the LSx family of engines? It makes me shiver to think about it.
The LSx is so totally new... it shares only bore center with the SBC... no part is interchangable.
The thing i really like about the C5 LS engine is that there are so many aftermarket parts available and they respond to mods so well, and a lot of the C6 and probably future Vette parts will fit. I think you can get the LS7 heads for around $1500 and they flow 360cfm!
I just don't understand how that can be possible.
When you go from a 23 degree head to a 15 degree head, who's to say the power you gain isn't 100 plus rwhp?
The difference is also port velocity too. With easier air path comes faster air velocity. Multiply that with bigger cams and more air from mods, and you see the major difference.
I believe that it is the efficiency of the head design that makes all the difference. I am far from the guru but my understanding is that the velocity of the airflow is is not being taken into account in your quote above. It's like the difference between putting a SBC head with lagre ports flowing high cfm versus a smaller port flowing a slightly smaller of cfm but at higher velocity. I'm not an engineer so the actual science is beyond me but this is what I have read in numerous sources.
What's the deal?
If the parts in the gen I engine are actually similar (in function and design) to what is on the LS1 engine the power output will be the same.
SBC has come a long way for sure. The port design and airspeed of the LS heads works so well you can use a 200+cc head and make good street power and get iot all upstairs. If I ever build another motor its going big CI LS.
Only thing I wish GM had done is apply another 15 years tech to the LT5, think of the possibilities.
They just havent pushed it as much in terms of "power" performance for street engines, with the Cadillac LeMans prototypes being killed off rather early in development. Why they did that, I dont know.
They are concentrating their research on fuel economy areas, but with Caddy aiming for MB and BMW, they'll soon push it for power. They just feel that the LS engine will be better and cheaper for the time being, I suppose.
