Really, really need Guru's help
Yestrday I removed two rockers and springs in order to see the oil seals on the valve guide. I was expecting worn or missing or fluctuating seals. NOTING the seals are perfect planted on the valve guide. And there is no play between the valve stem and the guide.
.The seals seems new too.
how can i collect a teaspoon of oil at the back of the Intake valve when this is closed. I'm missing something? The only way the oil can stay there it's thru the valve guide.... I'm wrong? some other test to try?
-Beppe-
Also you need to disassemble the heads to really check out the valves and the seals.
I just had my springs changed on my 2year old heads ~4k miles on them max, and the valves were worn severely??? Brodix uses junk stuff on their assembled heads and my intake valve stems were .008-.010" worn!
If the heads are off the car, I would have them taken apart and at a min new valve seals put in, yours could be dried/worn. Is it EVERY port that is getting oil? How do you know its coming from their? Reversion can deposit oil in the runners as well if your rings are not good. So can an intake leak.....
I'm sure there is rtv on the treads.
The seals (positive Viton) SEEMS like new.
I don't understand the Reversion thing...
Ok, during the overlap I can have some gasses returning up to the runners. But ...How can collet oil on the intake valve if the culprit are the rings? If the rings are worn (Leakdown test is GOOD..) the oil should be sucked in the combustion chamber and BURNED BEFORE to entering in to the intake tract and be collected o top of the valve..
I'm wrong? I'm using a 219 cam not a cam with a diabolical OVERLAP..
-Beppe-
RACE ON!!!
a considerable amount-I would almost eliminate seals, very well could be the studs-but still that's a substantial amount of oil-which leads me to believe there was a poor job done on the guides. Just my 2 cents.
Seals-maybe, but that's unlikely to account for that much oil on the valves-
Yes, the CFI EFI reasoning is what I allways thought.
But the two seals I removed seems right new, not distorted , not brittle. Yes, I tried the clearance of the valve stem at every valve lift an there is NO play. I also put a hand vacuum pump on the guide with the valve open and I can maintain vacuum.
I have not yet removed the studs, but I can see that there is RTV on it.
Probably the RTV is not good? I have to use a Teflon pipe sealant?
but even thinking that the RTV is not the proper sealant to use, it is possible that using RTV it's worse than using nothing?. I also thought to remove the heads...but on my little garage it's very difficult to remove all others parts involved. In addition I think it's very difficult to add the correct torque on each bolt of the head with the engine in the car.
-Beppe-
Permatex #2 is an excellent product for the studs. Prep is very imp. clean all thread thouroghlly, on bolts after all the crud is off I use some carb cleaner. The only thing about yours is I always 'chase' the thread w/a tap to get all the crap off the threads. On yours the old selant etc.will fall in, and I'm not sure you can if you can get a rag deep enough in there to prevent that (don't own that style head, mine don't go all the way through).
As to torquing and or removing the heads, the biggest PIA doing it in the car is re torquing the bottom head bolt #8 cylinder (pass. side).
I've NOT checked if the plugs are full screwed or with sealant because I haven't found yet an allen wrench so big to use with...
-Beppe-
I have a Mr. Gaskets product called Pro-Pipe teflon sealer non ardening compound... (I don't remmber if this is the right name ....but it's very similar...)
This is good for the studs?.
-Beppe-
I have a Mr. Gaskets product called Pro-Pipe teflon sealer non ardening compound... (I don't remmber if this is the right name ....but it's very similar...)This is good for the studs?.-Beppe-
I have never used liquid teflons in this area, so I would not want to lead you down the wrong road. If I only had the choice between the teflon and say ultra black or blue, I would go with the Ultra.
What I can tell you is Permatex #2 ('form a gasket'), is a reisin based formula not a teflon or silicon, according to permatex. Permatex has a # that might be able to provide you information on availabilty internationally 877-376-2839.
Sorry, I always forget where you live and what you must have to go through to get some things we take for granted.
The source can be the studs entering in the intake ports.
Putting a finger on these holes, the finger has a little of oil on it.
I tried to put a lot of oil on the stud from the TOP of the head, but there is no vacuum to allow the passage from the rocker area to the head port. I have a manual vacuum pump, but it's impossible to put the tube of the pump (or an adaptor) on the hole in the port of the head. Probably applying the vacuum directly on the port of the head will be a good test to see if the oil surrounding the stud can migrate in the port, but it's very difficult....I haven't an adapter of the shape of the port.
I'm open to suggestions to find a way to apply vacuum on the port.
-Beppe-
PS could I use teflon tape on the studs instead of the permatex 2?
