Suspension /driveline shift?
Hit the gas hard, the car goes left.
Let off the gas, the car goes right.
Bounce the pedel and you can feel the back of the vehicle shifting around.
Wise forum memebers said to replace the "dog bone" bushings, so I went in and did all the rear bushigs sans sway bar and bat wing.
Problem is still there. It feels like the whole rear of the car is loose!
Tie-rods look ok. Had the aligmenent checked before the bushings, and it was in spec. I know it needs another check after the bushing install, but I dont think this is alignment. You can feel something is sloppy.
Any ideas? Tranny mounts? Help!!
RACE ON!!!
The camber strut bushings on one side looked really bad.
The rest were give and take. Some were a little disfigured, others looked fine. I thought what the hell, its 17 years old, and for ~$150.00 and several hrs, it's done. Plus it keeps me entertained.
Just bummed it didn’t fix the problem. Thanks a ton for the suggestion though. It sure looked like it would be the problem.
Changed the dif. fluid a while back. The posi-traction seems to be ok. There is definitely something shifting around though. I would not expect the dif to make the whole car shift like it does. I would expect the dif to be more of a pull to one side or the other. Batwing bushings sounds possible, but they looked pretty good. And the amount of wiggle I feel in the drivers seat seems way to much. It feels like dog bone bushings are missing on one side!
Frame issues? What you mean? I’m the original owner. How can I check for a fame problem? Wouldn’t I have to hit something to screw the frame up that bad?
There is a large frame member that goes from the front to back along the propeller shaft. Could this be lose or something? Any suggestions are greatly appreciated!
I have a 4X4 pick up with a Detroit (Locker) Automotive No Spin in it. The nature of that diff is that no rear wheel can rotate slower than the ring gear. Under normal, straight ahead conditions The truck is being driven by the right rear wheel. When I take my foot off of the gas, the engine braking is through the left rear wheel. I haven't checked the rear suspension on the truck, but it definitely steers with the throttle. If I take my foot off the gas to slow down, I have to correct the steering with the steering wheel. If I step back down on the gas, the same thing.
RACE ON!!!
Tie-rods looked ok in the back. Havent looked at the front in a while.
Thought of a bad bearing last night, and was pulling hard on the tires while the car was on the jack to see if I could get any movement out of them. Bearings seem ok.
I'll get it on jack stands this weekend and get all the way under it to see if I can see anything. Whatever it is, its gonna be interesting when I find it......Thanks for the ideas.
movement at 12-6 would show bearings
Chris
I’ll keep digging.
Cant seem to figure this out.
Cant find anything that looks really bad, but something is certainly weird.
I’ll double check Tie-rods and have a different shop give it an alignment.
Thanks for the suggestions.
Don't only look at the outer tie rod ends at the wheels.
Tom Piper
