Help!! Replacing Water Pump 85
Old Apr 1, 2006 | 06:48 PM
ROCKY85's Avatar
ROCKY85
Default Help!! Replacing Water Pump 85
The problem is this was going to easy, Haynes says to loosen the bracket bolt under the lower edge of the compressor clutch (easy enough) wrong can't get to bolt does anyone know what size it is? does it require an open or box wrench?
ROCKY85
Old Apr 1, 2006 | 07:29 PM
geezel's Avatar
geezel
I believe it's a big Torx head bolt. There is a notch in the compressor clutch you must rotate over the lower bolt for proper access. At least that's how it is on my 86...
Old Apr 1, 2006 | 09:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Apr 1, 2006 | 10:49 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I believe it's a T45 torx bit to take it out and as geezel1 stated there is a notch on the a/c pulley that has to be lined up right so the bolt will come all the way out.
To Help!! Replacing Water Pump 85
