Popping from engine????? Help
Old Apr 5, 2006 | 09:53 PM
Bam's Avatar
Bam
Default Popping from engine????? Help
1995 vette 383 lt1 procharged 8lbs of boost, plugs sound like they are popping under 50% throttle.has a full tank of 5 month old gas could this be the problem? It has all the right parts from gas tank to air filter professionally done. Any advise would be appreciated. Thanks Bam
Old Apr 5, 2006 | 11:05 PM
lcvette's Avatar
lcvette
5 month old gas? with forced induction.. after that long sitting in a small container like a tank the octane rating has degraded below fresh 87 octane.. you are essentially running on **** gas.. if you don't plan on running the car hard or are planning a trip, drive lightly but I would at least put a few gallons of fresh 93 in to try and help part throttle detonation under light loads in your taller gears.. run it through then fill a fresh tank of 93 and that oughta do it!
the other alternative is to mix in some race grade fuel like a 112 from a track if you have one near by or a racing fueling station.. some here locally have at least 100 octane unleaded but is only dispensable in containers as the nozzle is larger then the hole for the gas tank.. good luck with it!
Chris
Old Apr 6, 2006 | 01:22 PM
Bam's Avatar
Bam
Default Thanks For The Info Chris
I was very happy to see your post, I want to throw a BIG THANK YOU your way. I was thinking the gas is the problem and when you posted it reassured my thoughts. Take Care And Thanks Again..... Bam
Old Apr 6, 2006 | 02:11 PM
mn_vette's Avatar
mn_vette
You might want to drop a thing of octane booster in the gas while you drive it dry. I hope some new gas will fix everything
Old Apr 6, 2006 | 02:48 PM
bill mcdonald's Avatar
bill mcdonald
Bam. lol. get that gas out of the tank.
I had my car down for 6 months running N/A. I got it together and took it for a drive. just cruisin about. a maxima came up and started messing with me, So I hit it, he hit it, and he pulled away from me. lol.
bad gas will make a fast car run like total ****. I siphoned it out, put in new, and it was back to how it should be. burning out in 2nd gear at 20 mph.
I would siphon, or pump that gas out. put it in the lawn mower and see if it even runs on it.
Old Apr 6, 2006 | 03:30 PM
Bam's Avatar
Bam
Default You Guys Are Great
Thanks, It's good to know you guy's are out there.
Old Apr 13, 2006 | 04:05 PM
Bam's Avatar
Bam
Default Just A Quick Update on Popping Plugs
OK, Got the bad gas out put some fresh 93 octane in drove it around a few miles then WOT presto 9lbs of boost now! No popping, no hesitation, YEH boy it feels good running like a champ all the way up to 6800 redline. Thank You For all your help.
To Popping from engine????? Help
