Lowered C4 owners step inside .........
Old Apr 6, 2006 | 10:15 AM
Hairmetal_still_rox!'s Avatar
Default Lowered C4 owners step inside .........
I am finally putting back together the front end of the car now that the rear is done and have installed the lowering wedges on the front spring. My questions is: Who has/has not removed the 1/4 inch thick aluminum spacer ( 1 inch wide by approx 5 inches long ) that sits up against the frame? Second part of the question is: How much did your front end drop? I am unsure whether to put the spacer plate back in and it was a real PITA to do this front end job and really dont want to have to do it again. Thanks all in advance.
Old Apr 6, 2006 | 12:21 PM
sonomacrew01's Avatar
sonomacrew01
I'll chime in but I think the front spring is different depending if you have a coupe, convertible or sport suspension.
I have a 93 40th convertible. I added the lowering wedges and cut off one of the spacers at the end of both sides of the spring (it had two 1/4" spacers at the end). I then bolted everything back up and it still didn't sit low enough. I then removed everything again to get the 1/4" sacer you are talking about out. I havent't driven the car around but there's enough for 2 fingers between fender and tire. I hope it settles a little bit more.
Old Apr 6, 2006 | 12:39 PM
Thanks, I have a coupe with the FX3 suspension but not sure which springs I have. I dont ahve a build sheet unfortunetely. The sway bars were the small ones ( 26mm fr and 24mm rr ). Anyway, I didnt notice any spacers at each end of the spring only at the two mid point mounting areas. I take it there are others at the lower control arms? I dont remember seeing any, thats funny.
Old Apr 6, 2006 | 12:41 PM
DieL's Avatar
DieL
on the bottom side of the spring near the ends you should see a 3 letter code. find the code and you can find out what spring # you have.
Old Apr 6, 2006 | 02:31 PM
Wheelman's Avatar
Wheelman
If you are talking about the spacers im thinkin about that are originally on top of the spring, I took them and put them back on underneath it. Thats what the instructions I got said to do.
Old Apr 6, 2006 | 05:44 PM
rstackjd's Avatar
rstackjd
Was it really a PITA? I'm thinking about getting a lowering kit for my '88 'vert (Z-52 suspension) but wasn't sure how much of a pain it was going to be and whether any special tools were required. How long did it take? Don't say any idiot can do it - I've learned I'm not just any idiot when it comes to things mechanical - I'm an extra special idiot
Lucky for me my son-in-law is a car guy with actual skills!
Seriously - how much time and what kinds of tools are needed for this job. Also, has anyone used the lowering kit for sale in the CF Store?
Old Apr 6, 2006 | 06:15 PM
86PACER's Avatar
86PACER
http://webpages.charter.net/khasting.../lowering.html
Old Apr 6, 2006 | 06:19 PM
rstackjd's Avatar
rstackjd
Beautiful! Thanks
Old Apr 7, 2006 | 01:26 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
After doing that I only dropped 5/8",, but have since learned my stock bushings were petrified wood. Since swapping bushings, the front has settled more, I'd guess about 1" total, but I haven't measured.
It looks damn low in this shot:
I removed the aluminum shims.
If you have the old style steel spring retainer brackets I highly suggest buying the newer aluminum ones and cutting them down.
Old Apr 7, 2006 | 01:53 AM
comp's Avatar
comp
Old Apr 7, 2006 | 08:02 AM
Stefan Nord's Avatar
Stefan Nord
Why dont just cut the steel brackets down!??
Old Apr 7, 2006 | 10:40 AM
CentralCoaster
You'll need a welder.
Old Apr 7, 2006 | 03:41 PM
Wheelman's Avatar
Wheelman
Ok nevermind....I didnt remove them I cut mine down. Its been so long since I did it i forgot
Old Apr 7, 2006 | 11:36 PM
aboatguy's Avatar
aboatguy
I have a Vert and I put the spacers on the bottom of the spring put the car together and went for a ride. The drop was not what I expected, so I took split the ball joints again and cut off half of the pads on the spring ends. Now I have a decent drop.
Mike
To Lowered C4 owners step inside .........
