What is Code 43 for a 92?
Old Apr 6, 2006 | 12:10 PM
slicked25's Avatar
slicked25
Default What is Code 43 for a 92?
I'm sure it's somewhat releated to me changing the upper radiator hose the other night. Does code 43 mean knock sensors?
Old Apr 6, 2006 | 12:23 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
http://www.tradervar.com/GM_Codes.htm
43 Electronic Spark Timing (EST) Circuit - low voltage detected
Check this instead. not sure what the diff except this is more accurate for your year....
http://www.troublecodes.net/GM/92-93_57P.shtml
42 The EST circuit voltage was below 0.5 volts when engine speed was below 3000 RPM.
43 One or both of the knock sensors were either open or grounded for 5 seconds.
Old Apr 6, 2006 | 12:25 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Trouble Code 43 indicates that there may be a malfunction in the Electronic Spark Control (ESC) circuit.
Check the knock sensor connectors to see if they're loose or not connected. Check for grime, too. Also, did you remove the sensors? I believe the correct torque spec is 13 lbs. You may not have them in tight enough or have them in too tight. Check your Helms manual.
Old Apr 6, 2006 | 12:53 PM
slicked25's Avatar
slicked25
No, I didn't remove or touch the knock sensors. When I got in from work last night while ideling is when the SES light came on. Thanks. I'll go check it out before going to work.
To What is Code 43 for a 92?
