What is a Quad driver?
Old Aug 26, 2013 | 10:24 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Originally Posted by VR'92
Getting a Quad Driver code does not mean the ECM is failing. I could just be the system that the QDM controls is failing. Most likley it is not an ECM failure. You need to get a service manual and look up the code.
I have had quad driver codes in the past and fixing the system causing the code cleared it.
Old Aug 26, 2013 | 04:54 PM
Cliff Harris's Avatar
Cliff Harris
A quad driver is an electronic switch with 4 parts.
They are used to turn on relays and solenoids. They have protection circuitry built in that will set a fault if it detects high current. The problem is usually in the circuit being controlled, not the quad driver (and therefore not an ECM/PCM problem).
The troubleshooting procedure is:
Determine which circuits are being controlled by the quad driver in question.
Disconnect all the circuits involved.
Reset the ECM to clear the error codes.
Plug in the controlled circuits one by one and check to see if the error has come back.
When you get an error code then the last circuit connected is the one with the problem.
You can also check the various circuits with a meter to see if there is a short, either in the device or in the wiring to ground.
Old Aug 27, 2013 | 03:27 AM
Cliff Harris
Originally Posted by OldCorvetteFan
Here's a link to some general information about quad drivers ...
http://www.onsemi.com/pub/Collateral/NCV7601-D.PDF
Steven
The earlier ECMs used this guy:
http://www.ti.com/lit/ds/symlink/tpic2404.pdf
