rough idle at start up cold
Old Apr 6, 2006 | 03:04 PM
hog117's Avatar
hog117
Default rough idle at start up cold
When i go to start the 92 when cold it will idle low wanting to stall if i give it a little gas it idles fine also when it gets warmed up its good any ideas ? thanks
Old Apr 6, 2006 | 03:42 PM
ittlfly's Avatar
ittlfly
Sounds like the IAC has a problem. Any codes?
Old Apr 6, 2006 | 03:53 PM
rickneworleansla's Avatar
rickneworleansla
I'm having the exact same problem. (See threads below) Someone's gotta know. No codes shown. Keep me up to date if you figure it out. This weekend I'm going to start by changing the fuel filter and fuel injectors. (Something I wanted to do anyway)
http://forums.corvetteforum.com/show....php?t=1343675
http://forums.corvetteforum.com/show....php?t=1351435
Old Apr 6, 2006 | 05:38 PM
hog117's Avatar
hog117
nope no codes just low idle
Old Apr 6, 2006 | 07:01 PM
ittlfly's Avatar
ittlfly
When was the last time you cleaned the TB and the IAC? I'd start there and then reset the IAC according to the FSM.
Old Apr 6, 2006 | 08:35 PM
pcolt94's Avatar
pcolt94
I have been cleaning, fixing a re-setting those idle speed control motors for the last 20 years on all kinds of cars we have owned. Yes I have had some success, and other times done the job again many times over. That was then, now I don't mess around with them anymore except to troubleshoot the problem. I just change them out now because their so tempormental and I just want to get the problem fixed and be done with it. And yes I know there expensive, but easy to change and at least you know where the problem is not. But it's usually money well spent and generally takes care of the problem.
Hope I have not stuck my foot in my mouth to far, good luck!
Old Apr 6, 2006 | 08:36 PM
RRT vette's Avatar
RRT vette
Just did this to my TB and the car starts quicker now! No codes, this would be a good place to start.
Old Apr 6, 2006 | 08:41 PM
SunCr's Avatar
SunCr
When the engine is cold, the ECM doesn't correct fuel delivery for minor vacuum leaks, plugged up injectors or sensors that are working but reporting the wrong info. Scanning it in closed loop (warmed up) will tell you what corrections are being made - more fuel or less - and lead to a better diagnosis. Before you start, verify that the Coolant Temp and Manifold Air Temp Sensors read the same and are close to the outside air temp.
Old Apr 6, 2006 | 08:43 PM
pcolt94's Avatar
pcolt94
Another thing to try. Disconnect the battery terminal, leave off for a minute and reconnect. This will reset the PCM and it will have to re-learn the idle speed. This will probably not work but you never know when a BIT might be hung up in the PCM computer.
Just another thought.
Old Apr 7, 2006 | 10:45 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It could also be the EGR valve.
If the engine's getting too much EGR flow at idle, cruise, or cold operation, the engine could stall after start, the engine could stop at idle after deceleration, the car could surge during cruise, or the engine could exhibit a rough idle.
Old Apr 7, 2006 | 04:53 PM
hog117's Avatar
hog117
Default i think i got it
Well after reading everything i put my finger in the tB and it was black so i moved all the moving parts i could see on the TBthen i disconnected the battery and waited then connected it started it up and it was fine can i spray TBcleaner in and around instead of taking apart thanks for all the help
Old Apr 7, 2006 | 10:12 PM
RRT vette's Avatar
RRT vette
It won't hurt to use carb cleaner in there, thats what it's for. But to prevent this problem in the near future , i would take the TB off and remove the IAC sensor. There are holes in the TB that you can't seen unless taken off. Buy a new 3 dollar TB gasket and a few cans of carb cleaner and a thin wire brush. In about 30 min. it will be new again. This will make it run a lot better IMO.
Old Apr 8, 2006 | 01:42 PM
rickneworleansla
Default hesitation
I chahged the fuel filter and cleaned the throttle body with carb cleaner and that seems to have help some. It wasnt stalling this morning. Maybe still hesitating. It's hard to check because it only does it when cold. Should I dissamble the throttle body and clean it apart? If so how and what should I look for? What is the IAC sensor? Where is it? How do I check it? How do I check the TPS?
Old Apr 25, 2006 | 09:48 AM
rickneworleansla
Default stall
Sounds like you may have found your problem but if not clean the MAF sensor with some cleaner you can buy from PepBoys. Thats what fixed mine.
Old Apr 25, 2006 | 09:51 AM
onedef92's Avatar
onedef92
Start by cleaning out your throttle body (TB) and Idle Air Controller motor (IAC). I did mine last weekend and it cured both my high idle problem and my stumble during cold start-ups.
That new Valvoline SynTech Throttle Body Cleaner is GM approved and runs about $2.04 a can at NAPA. Great stuff. Use it and an old toothbrush and a couple of shop towels to get it clean and restore performance.
Old May 3, 2006 | 10:26 AM
cantgrowupyet's Avatar
cantgrowupyet
7th Gear
Default what next?
I have changed the IAC, ECM, plugs, cap and rotor, all intake manifold gaskets and the car has been to a vette garage BUT it still has cold idle fluctuation until it's warm. Any other ideas? Anyone?
Old May 3, 2006 | 10:32 AM
runner140*'s Avatar
runner140*
Maby....if the above, IAC, ECM, plugs, cap and rotor, gaskets etc. didn't work, why not try ($5.88) a can of "SeaFoam". It worked for me.
To rough idle at start up cold
Old May 22, 2006 | 01:50 PM
cantgrowupyet
7th Gear
no
the seafoam is not the answer. It has to have something to do with eletrical I would bet, or a vaccuum leak? Any other thoughts?
Old May 22, 2006 | 04:29 PM
rick lambert's Avatar
rick lambert
cantgrowupyet, I didn't see the year of your vette..and your profile is empty...but if you have a CSV also referred to as the 9th injector, you may want to check there.
Old Jun 1, 2006 | 02:10 PM
cantgrowupyet
7th Gear
I'm sorry. I added some info to my profile. I have an 84 corvette with a 96 body conversion. I have taken it back to the shop "Corvette Village" to see if they can find anything.
Thanks for the reply! If you have any helpful tips - I will pass them on.
Well - they have not got the answer yet. Now we have changed the prom chip with some improvement but it still idles funny.
Could there be a grounding problem???
