From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
PB Blaster is the deal!
I bought some of this last year to supplement my stock of Liquid Wrench. I never really had an opportunity to give it the acid test until I did some parts removal on an original 92K mile '49 Ford the last few days. Everything I've used it on has come loose except for one manifold stud for the downpipe which did require a bit of heat. I soaked the intake and exhaust studs overnight a couple of times and when it was time to remove them, no problem. I hope the mods will recognize that I'm passing on info for a productive tool for anyone who has to take apart things that have been together for a long time. The fact that I just happened to really be impressed by it occured while working on an ancient Ford, notwithstanding. This car is really cool by the way. All original, unmolested and runs damn good. I'm just making it run better!
Just bought my first can 2 days ago! After listening to my friend talk about it for years. It will replace the Liq. Wren, Pzl Penetrating, etc.
One note: my friend said he's soaked stuff with that not just overnite, but for as long as a couple days. Don't know if that would've worked in your case, Chris, but maybe next time?
That's what I did with the intake and exhaust manifold nuts as I knew I'd be removing them. I sprayed them at night a couple of times, drove the car during the day, and when I got ready they came right loose. I've worked on a lot of old cars in my time. But it is rare to work on one that is so original and has not been screwed up by a multitude of butchers over the years. I have found the experience quite therapeutic. And I am trying to resist the impulse to buy this car when it becomes available, which it will.
We use that stuff at our shop and it works wonders on everything to bolts,nuts,bugs,pissy attitude people,it just works!
My emoticons aren't working but I read your post and laughed out loud!!!! Good one. Especially about "the people". Hmmm, may work on some encountered on some forums....
I've been using PB blaster for a while now. My friend was taking apart his truck and I noticed him using it, said it worked really good. I use it for all kinds of stuff besides loosening bolts. Its good at lubing up stuff and preventing rust, like WD-40.
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
i use it on the tough stuff, but it's too expensive to drown things in.
a while ago, i bought a gallon can of wd40 from harbor freight for around ten bucks and squirt it with an old time squeeze pump bought for a couple more. i drown regular jobs with the with the wd and use the pb for the hard stuff. i calls it love juice.
At work we call penetrating oil weasel ****. I have no idea why....
