1986 Rattle After Cold Start?
Old Apr 8, 2006 | 08:40 AM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default 1986 Rattle After Cold Start?
What could this be I have heard this on some 84-88 Vettes. When you start the car it sounds like the fuel lines rattle on the right side. The car has this rattle somewhere under the door area. Once the car warms up it seems to go away.
I checked the fuel lines from the filter back along the floor and they seem tight. I removed the inner wheel well and followed the lines back and found one spot where I though it could be rattling. I cut a piece of rubber hose and put it between the two lines. I also found the line to be touching the side of the gas tank and moved it away.
I can't seem to find what is making this noise.
Old Apr 8, 2006 | 08:53 AM
rick lambert's Avatar
rick lambert
Cats rattle when their on the way to the dump.
Old Apr 8, 2006 | 09:21 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Iv'e heard my fuel lines rattle from time to time. The pulse from pump will cause this to happen. I believe there is pulse absorber of sorts in the fuel sytem that may be failing.
Maybe a fresh fuel filter will help
Old Apr 8, 2006 | 09:27 AM
AGENT 86's Avatar
AGENT 86
They call it a "pulsator damper assembly" and it's mounted on top of the fuel pump.
Old Apr 8, 2006 | 09:48 AM
PAINTER MAN's Avatar
PAINTER MAN
My 86 does the same thing when cold. I believe this was a issue and was addressed on GM service bullitens. I guess mine and yours was never fixed.
Old Apr 8, 2006 | 11:51 AM
MrRenoman's Avatar
MrRenoman
My 'ol '85 did and still does it. Only on cold days in the morning. It's a rattling sound under the car. Never found where it was coming from. Even had a new catalytic convertor. Guess it's common...
Art
Old Apr 8, 2006 | 11:54 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It's called Fuel Line Hammer.
FUEL RETURN PIPE RATTLE/KNOCK TSB
Old Apr 8, 2006 | 06:35 PM
Corvette ED
Thank You to everybody for helping me fix this problem.
Old Apr 8, 2006 | 09:43 PM
kize's Avatar
kize
anyone know what this kit looks like or where you can get one?????
To 1986 Rattle After Cold Start?
