Please Help...
Old Apr 9, 2006 | 10:19 PM
brokemxer's Avatar
brokemxer
Cruising
Default Please Help...
I just changed out my cap and rotor and now my car wont start. I have landed all the wires right according to my manual and have even checked them against my dads 86. I have spark. I didnt change the angle of the distributor. Ive done this many times before and didnt have any problems. What am I missing? If it matters my car is an 89 auto convertible.
Old Apr 9, 2006 | 10:31 PM
aminnich's Avatar
aminnich
Are you getting spark at the plugs? If yes then double check to see rotor is same as old one and installed correctly. No spark=check for ignition wire you might have left loose, including coil wires.
Old Apr 9, 2006 | 10:40 PM
brokemxer's Avatar
brokemxer
Cruising
Checked for spark. Its there. And I checked to see if I was 180* off. Car wouldnt turn over so I assume that Im not 180* off....
Old Apr 9, 2006 | 11:37 PM
MrRenoman's Avatar
MrRenoman
There's 3 connectors that go to the distributor. They're all on?
Art
Old Apr 9, 2006 | 11:43 PM
rick lambert's Avatar
rick lambert
when you changed your cap-did you hook up the ground on the coil?
Old Apr 9, 2006 | 11:48 PM
brokemxer's Avatar
brokemxer
Cruising
All 3 connectors are hooked up. Ground is hooked up....
Old Apr 9, 2006 | 11:50 PM
madmike's Avatar
madmike
make sure your wires are setup correctly. 18436572 firing order. But first i would take off number 1 plug and stuff a rag in it to find tdc on number 1. When it pops, trace the plug wire to the distributor and look under the distributor cap. Is the rotor lined up with the wire? Sometimes this is off by a wire and the whole thing is off. If everything was placed back correctly, possible the module popped. I usually carry a extra module just in case. Hope this helps...
Old Apr 10, 2006 | 07:44 AM
kalister1's Avatar
kalister1
Check the spring loaded contact inside the cap?
Old Apr 10, 2006 | 07:57 AM
Runum's Avatar
Runum
You might check around the distibutor for any pinched wires between the cap and the dist body. Good luck.
Old Apr 10, 2006 | 10:48 PM
brokemxer's Avatar
brokemxer
Cruising
Thanks for all the help. I used mad mikes idea to find tdc on #1 and found out the distributor was set about 200* off of where it should have been. Put everything back together accordingly and it fired up perfectly. Thanks again for the help.
Old Apr 10, 2006 | 11:10 PM
MrRenoman's Avatar
MrRenoman
Interesting. I didn't know you pulled the distributor out to change the cap and rotor. Good you got it fixed...
Art
To Please Help...
