What does it sound like
Old Apr 10, 2006 | 12:34 AM
Getzen88's Avatar
Getzen88
Default What does it sound like
when a u-joint is going? when i start in first, it sounds like i'm draging cans behind my rear drivers axle. could it be the u-joint or is it something else?
Old Apr 10, 2006 | 01:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You'll get a clunk when you take slack out of the drivetrain on and off the throttle.
Old Apr 10, 2006 | 08:03 AM
CMYC4GO's Avatar
CMYC4GO
That my friend, is exactly what a half-shaft u-joint sounds like, and/or a clunking sound when you turn a corner.
Old Apr 10, 2006 | 08:30 AM
Getzen88's Avatar
Getzen88
great, just $$$ after $$$ going into it now
Old Apr 10, 2006 | 09:41 AM
tuband's Avatar
tuband
Cruise-In I Veteran
Not necessarily .... get some spicers (do a search on the forum for the correct numbers). They should be around $14-15 each. DIY ... the job is not difficult at all. Good luck.
Old Apr 10, 2006 | 05:15 PM
Black'92's Avatar
Black'92
Couldn't the problem also be rear hub bearing assembly?
To What does it sound like
