Techline Tech1 Questions
Old Apr 10, 2006 | 07:21 AM
kalister1's Avatar
kalister1
Default Techline Tech1 Questions
I just bought a Techline Tech 1 scan tool from E-Bay. It came with 1 cartridge for 86 to 92 GM ECM. I have a 93 Corvette, when I ran the on board diagnostics it came back as a 92 ECM (The diagnostics that read back from the speedo) So can I use this cartridge on my car? If the software is not compatible will I damage anything by hooking it up?
Old Apr 11, 2006 | 01:36 AM
corvette1989bham's Avatar
corvette1989bham
You wont hurt it, the cartridges are cheap , what you NEED is the MASS STORAGE CARTRIDGE ..it has most of the others built it. You will also need a y/f body adapter to read data from 350 TPI engines as well.
Good Luck....you can PM me with questions.
