sudden rich condition while driving to work
Fast foward to this past weekend when I replaced the clutch and flywheel with stock LUK parts. No issues 'til this mornings trip to work. I noticed the average fuel economy reading start to decrease about 45 mins into my 3 hour drive. I normally see 23.1 mpg, but it steadily decreased to 20.0 mpg by the time I arrived at work. I also noticed an increase of "popping" in the exhaust, and near the end of the drive when the road was clear to accelerate, black exhaust. The SES light came on, but it usually does on the highway because I removed the egr.
During lunch, I will attempt to pull the codes, check the resistance of the fuel injectors and check the fuel pressure (I need to buy the multimeter and fuel pressure guage).
I had a long weekend putting the clutch and flywheel in and a long drive back this morning. I'm looking for some feedback to check if i'm heading in the right direction, some other checks I can do to diagnose the issue, and people's experince if they've had a similar problem.
Thanks,
The one I had that failed went "tick-a tick-a tick-a-pause-tick-a pause-tick-a tick-a-pause". There is not supposed to be a pause. During the pause the injector is stuck and will flood that cylinder causing the rich condition.
This may not be your trouble but until you pull codes and post them I thought it may be worth checking.
Before I converted to heated sensors they would get very cool, the car would dump more fuel, cooling it off further, causing it to dump more fuel, until the car would barely run and it would burn your eyes. If I could get it to run at a sufficiently high enough RPM to warm up the O2 sensors so that they actually responded, it would run fine again until it cooled off.
If you have access to a scan tool it would be useful to watch your O2 sensor and fuel trims. You might be able to determine where the problem is without ever popping the hood.
I used the paper clip method and got one code, 44 (low voltage O2). Now I'm wondering if I plugged the O2 sensor back in
I'm fairly confident I did, though. I hope it won't do too much damage waiting 'til the weekend to replace it. I don't have any place to change it, or a jack to lift the car.Thank you for the tip on listening to the injectors. I'm fighting a rough idle, smoothe high rpm condition. A lot of the rough idle was fixed by the replacement of the dual mass flywheel, plus I believe I hear a spark going to ground through the plug wire. The car has 140k miles, so I'm sure there's a ton of stuff that needs replacing, but I do want to make sure I replace stuff that needs replacing.
I've been thinking about a heated O2 since I did the headers 4 years ago. I may instead try the WB O2 hack for the ECM. Or, one of the WB kit's has a simulated NB output, so I wouldn't have to hook up two sensors.
But I think it's going to be an injector.
It just started for me as well.... JUST when I thought I had the damn thing together.
And it was an aftermarket unit (Holley).
