Best cheap performance mod
Old Apr 10, 2006 | 12:47 PM
Qcarver's Avatar
Qcarver
Default Best cheap performance mod
What is the best performance mod under $300 that I could put on my 1990 corvette conv't Auto?
Old Apr 10, 2006 | 01:31 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
If you don't already own them, a scan tool and a factory service manual would be the best possible ways of spending that money. Get to know each one well
The performance upgrade road is long, windy, and treacherous . Generally, you get what you pay for. In the world of Corvettes, $300 won't really give you a noticeable difference, though a customized tune (NOT a hypertech chip) might be able to get the most from what you've already got.
Old Apr 10, 2006 | 01:59 PM
JEFNLSA's Avatar
JEFNLSA
Have Alvin @ pcmforless.com (or somebody local) burn you a chip. If you're still running the stock exhaust, you could also use that $300 or so for some upgrades there.
Old Apr 10, 2006 | 02:10 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
1.6 Roller Rockers and LT4 springs.
Old Apr 10, 2006 | 02:26 PM
Nathan Plemons's Avatar
Nathan Plemons
Alvin's a great guy and I would not want to cost him any business, but you'd really be silly to spend money on a performance chip if your car is stock. Save the chip tuning until you have some performance mods that dictate it and you'll save money and see a noticable difference.
Old Apr 10, 2006 | 03:17 PM
neat's Avatar
neat
Nitrous. You could piece together a kit from various parts off E-bay and your local hardware store for $300.
Other than that, the best gain at the drag strip for $300 would be tires.
I think the most power (other than nitrous) for $300 is probably rockers, or maybe a cheap cat-back system.
Old Apr 10, 2006 | 04:01 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I know I can pick up even a stock car so if he wants to try it and see how it works for him I'll refund the money if he doesn't like it.
The last stock car I did picked up 17rwhp last wednesday.
Old Apr 10, 2006 | 04:27 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The best mods for the buck are ones that won't gain you any hp at all, but will make the car quicker.
Gears (about $300 not including labor)
Shift kit
Higher stall tq converter
Old Apr 10, 2006 | 05:17 PM
Rapid Fred's Avatar
Rapid Fred
It really depends what you want.
Nathan really knows what he's talking about. But if (like me) you are not a wrencher, and all you want is to spend $200 and get more responsiveness, and a noticeably better top end, I would bet PCMforless (or an equally reputable chip burner -- not a "one size fits all") is the absolute best mod for the money hands down. Do be sure your maintenance is fully up to date, first, otherwise you are polishing a t*rd!
I did it and was amazed at the improvement. Others will confirm this.................
Old Apr 10, 2006 | 05:44 PM
GeosFun's Avatar
GeosFun
If you are talking about performance at the drag strip, then a set of drag radials will help you more than anything else.
Old Apr 11, 2006 | 05:56 AM
93 ragtop's Avatar
93 ragtop
Let me make a suggestion and also I am going to assume you will do the work yourself and assume you are in a area where smog test are not required.
1. Purchase or find someone giving away a LT1 stock exhaust. Install it and cut and weld back to your existing exhaust close to the motor.
2. Take Alvin up on his offer of tuning with a moneyback guarentee.
These two things should be able to be done for $300.00 if you do all the labor yourself. Next start saving for a set of 1.6 rockers and springs.
To Best cheap performance mod
