Anyone try Eckler's autocross Bilstiens?
Thanks,
Mark
For most vehicles including full-size sedans, wagons and most trucks, these units provide improved handling and stability without sacrificing the ride. Their superior damping ability makes them ideal for heavy hauling or occasional off-road use - while still maintaining an exceptional "street" feel. As with all Bilsteins, these units instantaneously self-adjust to changing road surfaces. In addition, their performance does not gradually decline from age, use or heat - requiring no compensating manual adjustments as with conventional multi-tube units. All Bilsteins listed in our Online Catalogs are considered a Heavy Duty Valving unless specified otherwise in the catalog listing.
Bilstein Comfort Valvings -
Some vehicles come equipped from the factory with a Bilstein made shock. Specifically GM vehicles, Mercedes, and others. These units, while built by Bilstein, are made and valved to the car manufacturer's specs, not Bilstein's. They will have a soft or "light" valving. While they are still a monotube shock, they typically do not dampen as well as a Bilstein with Heavy Duty or Sport Valving. (most Customers upgrade to a HD or Sport valving Bilstein if more performance is desired.)
Bilstein Sport Valvings -
For the performance minded driver, Bilstein Sport units deliver absomute mastery of the road surface. Designed to push a car's suspension to its performance peak, these super-firm units are well suited for use with special springs, anti-sway bars, and other suspension upgrades. As with other Bilstein units, Sports are uniquely self-adjusting.
Bilstein Ralley and Race Valvings -
Bilstein units designated Ralley or Race are specifically set to meet the rigourous demands of driving competition. Their success should be measured by the unprecedented levels of acceptance and use by professional drivers in virtually all major motorsports. Ralley and Race units may include such features as spherical bearings, adjustable spring-seats longer or shorter than standard dimentions. They and not suited for street use.
I would say what they offer as "AUTOCROSS" valving would be the Sport's...Not 100% sure though....
I've run the sport shocks for two years now in combination with the standard springs but changed to the Z-51 stabilizer bars. I like the softer spring (than a Z-51) on the rougher autocross courses that sometimes happen and for the small amount of street driving I do.
I've driven a Club members '95 with the standard Bilsteins and can really notice the difference in the way the car transitions like in a slalom. My car is much quicker in direction change but does pay the price in ride quality.
It is possible that Ecklers has asked Bilstein to make a valving between the Sport and the standard Bilstein valving.
Oh, my car is a '96 LT-4 Collector's Edition
Locke McCormick
North Florida Corvette Assn.
Jacksonville, FL
If you're serious about competing, step up to something like the Koni yellow's - you'll get some adjustment to play with and tune for the conditions, but are going to spend a bit more.
VBANDP, you guys watching this, care to chime in?
I hear them ranked as the second best shock for our Vettes, behind Koni Adj...and maybe qa1s...mine lasted 135k without leaking...
Where is the info from, you got me curious.
Locke McCormick
Jacksonville, FL
