How can I get VATS number?
Bob
VATS Key Codes and Associated resistance
Codes in OHMS
Pellet Resistance
Code Ohms
1 - 402
2 - 523
3 - 681
4 - 887
5 - 1130
6 - 1470
7 - 1870
8 - 2370
9 - 3010
10 - 3740
11 - 4570
12 - 6040
13 - 7500
14 - 9530
15 - 11800
Art
Bob
1 402 386 438
2 523 502 564
3 681 654 728
4 887 852 942
5 1130 1085 1195
6 1470 1411 1549
7 1870 1795 1965
8 2370 2275 2485
9 3010 2890 3150
10 3740 3590 3910
11 4750 4560 4960
12 6040 5798 6302
13 7500 7200 7820
14 9530 9149 9931
15 11800 11328 12292
If you don't know how to use a multimeter (voltmeter, ohmmeter), just take your key to your local Radio Shack, and have the measure the resistance value on the embbedded chip on your key. Then use the above chart or goto http://asttraining.com/Files/vats1.pdf and have them tell you what it is. Then seach for VATS Key on Ebay. I got mine for $8.00 ea. But you have to know the resistance of your orginal key.....
Art
I then ask if they could cut it for me. Some seem hesitant, by once I let them know that I won't hold them responsible if it's miss-cut, then they always do it. If fact, they think its cool that they can cut a resistor key using their normal cutter. Go when there not busy....
Measured in at 679 ohms. Its a number 3 key. Super easy.
No more annoying lights popping up all the time under bridges and generally whenever they feel like it
I did that, as well as cross-referencing it with the ohms reading, then bought my blanks on ebay for $10 each. Dealer wanted $35 each.
I then took the blanks to Walmart one night. The guy wasn't busy and was happy to cut them along with some house keys I was having made. He wouldn't charge me for Vette key cutting!
Bob
Bob
1. Always remove the fuse for the air bag...
2. Unconnect Yellow Air bag wire.
3. Remove battery (You need it removed to remove the column screw)
4. If you haven't purchase a one, get quotes from recyclers list in this forumn. The price of Steering columns run about $125.00
5. The column you get will have the key, but the resistor will probably be something other that what you have. The key is only needed for the key cut. Don't let the locksmith cut you a key with this VATS value because your VATS will probably be something else. Remember, your CCM module holds the resistor value, your column doesn't know anything about VATS. Luckly, the steering column I purchase had the same value as my other one, so I was lucky.
6. I recommend buying the key on Ebay (about $8.00) and just take it to Home Depot, Loews, Walmart. They will cut it for free (since you are providing the blank)
