car drifts
Old Aug 18, 2001 | 10:48 PM
fastrob's Avatar
fastrob
Default car drifts
my car drifts new tires allinment perfict some one said it was my stabalizer bushings does that sound right and how hars to replace :U :cry
Old Aug 19, 2001 | 01:51 AM
jfb's Avatar
jfb
Default Re: car drifts (fastrob)
Stabilizer bushings should not affect drift. Check tire pressure. You could have a tire with a separated cord, but I would take your car back to where it was aligned and have them measure the alignment. ALL 4 tires need to be aligned, not just the fronts. On a level flat road at constant speed , your car should go straight as a string with no hands on the steering wheel.
Old Aug 19, 2001 | 01:57 AM
korvetkeith's Avatar
korvetkeith
Default Re: car drifts (jfb)
If your alignment is arrow straight wide low pro tires will grab every crack in the road. Get another alignment with the front tires toed in more than on your current alignment.
To car drifts
