MSD or Taylor
Old Apr 12, 2006 | 06:25 PM
rickneworleansla's Avatar
rickneworleansla
Default MSD or Taylor
Which spark plug wires should I go with? Jegs has the MSD 8.5mm (part#32173) for $77 http://www.jegs.com/webapp/wcs/store...chItemId=81329. Taylor has several differnet types to choose from ThunderVolt 8.2mm, TV 50 custom, High energy, etc.. http://www.taylorvertex.com/hp/index.cgi/SparkPlugSets
The taylors range from $54 to $112 at Summit. Will these be a perfect fit as well and which one should I choose if you suggest the Taylors? Also is there a high perf coil I canpurchase for this thing? Not too familiar with optispark. I don't even remember seeing a coil in the engine compartment. Looks like Exotic muscle sells one http://www.exoticmuscle.com/webpage....&CATSEL=ENGINE Part number C1322.
. Is that the right one?
thanks
Old Apr 12, 2006 | 06:58 PM
Aaron71771's Avatar
Aaron71771
Im partial to Taylors wires myself. Havn't had a problem with them yet. Its what I have on the LT5 and it runs gooooood.
Old Apr 12, 2006 | 07:00 PM
C4driver99's Avatar
C4driver99
Taylors I think they are reputable and they give a variety of wires. Also you get what you pay for so Id stick with something that a bit pricier and less headaches down the road. Goodluck
Old Apr 12, 2006 | 11:33 PM
Lichen's Avatar
Lichen
I assume that you are talking about spark plug wires? I'd say that they about equal. I have the MSD 8.5 mm for about 3 years and have no complaints. I assume that Taylors are about the same.
To MSD or Taylor
