Oil temp. Reading
Old Apr 13, 2006 | 08:53 PM
HG's Avatar
HG
Default Oil temp. Reading
Does the analog gauge and the digital readout get it's info from the same sensor. Usually, the digital reads around 200, and the analog reads barely 100. I know 200 is the correct temp.
Old Apr 14, 2006 | 08:18 AM
mseven's Avatar
mseven
There is only one oil temp. sensor I know located above the oil filter. Mine runs at about 180ish and w.temp about the same (scanner info from the ecm). The analog gauge is nowhere close which leads me to believe the analogs in these cars are lazy and not very accuarate. Your digital is probably is the info that the ecm "sees".
Old Apr 14, 2006 | 09:26 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can try replacing the oil temp sensor first. "Lazy guage" a common C4 problem. They run about $10 or less at AutoZone, NAPA, and other parts stores.
Old Apr 14, 2006 | 09:37 AM
comp's Avatar
comp
so the ECM split's the signal ??
To Oil temp. Reading
