Changing to roller rockers
Old Apr 15, 2006 | 10:16 PM
Jansenwins's Avatar
Jansenwins
Default Changing to roller rockers
1985 stock L98. Previous owner changed out 1.5 rockers to 1.6 stock-like rockers (they are not rollers or even roller tip). I've always ran Harlan Sharp aluminum roller rockers on my latemodel racing engines with no failures. 2 questions....will changing to a 1.6 roller rocker give a little more power? and can I just swap out the rockers, adjust the rockers correctly, and not have to make any other modifications? Thanks.
Old Apr 15, 2006 | 10:56 PM
redrose's Avatar
redrose
i tried 1.6 roller tips on my stock l98, found no noticeable improvement.
Old Apr 15, 2006 | 10:59 PM
rodj's Avatar
rodj
Given the wimpy specs on the stock cam money would be better spent on a cam change.
Plenty of choices that wiill give better results without the rocker change which you can always do latter.
Old Apr 16, 2006 | 01:25 PM
John A. Marker's Avatar
John A. Marker
You will get a little more power with 1.6 RR. I used 1.5 on the exhaust and 1.6 on the intake. No installation problems. Dyno reports on the Forum have indicted about 8 HP (+) gain depending on engine and other options.
Old Apr 16, 2006 | 04:09 PM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
I intend also to change to 1.6RR in my 84 L98. Will the gain be more noticable when the CFI intake manifoldhas been ported and when 1 5/8 headers are mounted?
Old Apr 16, 2006 | 04:55 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
a. "....will changing to a 1.6 roller rocker give a little more power?" - Yes. You should pick up a couple ft.lbs. of torque from reduced friction. If the stamped-steel piece you are running is experiencing any flexion under load, the roller rocker will eliminate this as well.
b. "and can I just swap out the rockers...and not have to make any other modifications?" - If you are *already* at 1.6 (and valvetrain geometry is already correct, etc.) then you won't have to worry about springs, pushrod length adjustment, etc.
To Changing to roller rockers
