Second right O2
Old Apr 16, 2006 | 12:00 PM
larrynash's Avatar
larrynash
Default Second right O2
I have a 95 and found that the second O2 sensor on the right side has gone bad. It is very lazy. The primary front left and right O2 sensors were replaced and are working well. Will replacing the bad sensor help how the car is running? I understand it is used to check the cat.
Old Apr 16, 2006 | 04:14 PM
Morley's Avatar
Morley
Well, that depends on how it is running. First we'd need to know any symptoms of it not running right before an answer can be given.
Old Apr 16, 2006 | 09:49 PM
STL94LT1's Avatar
STL94LT1
Replacing the post-cat O2 sensor on a 94/95 will make no difference. Many have eliminated this sensor, without a problem.
Old Apr 17, 2006 | 12:09 AM
VenkmanP's Avatar
VenkmanP
It has no effect on the operation of the engine.
If you understand that, then you know the above answer already.
To Second right O2
