Open loop sensors, fuel delivery
Old Apr 16, 2006 | 02:32 PM
rickneworleansla's Avatar
rickneworleansla
Default Open loop sensors, fuel delivery
Can someone tell me what sensors the car uses for fuel delivery when cold and in open loop? I'm still having extremely low acceleration and backfiring at 1/2 to 3/4 throttle up until about 150-170. I recently changed the fuel filter and injectors, spark plugs and wires are next.
Old Apr 16, 2006 | 02:39 PM
vader86's Avatar
vader86
Should be the TPS and coolant temperature sensors, maybe LT1 monitors something else that I dont know about.
Old Apr 16, 2006 | 03:04 PM
rick lambert's Avatar
rick lambert
I probably need to read more on the coolant temp sensor, which when the engine is in open loop (cold) sends a high signal voltage to the ECM, as the engine warms the voltage signal becomes low.
Old Apr 16, 2006 | 04:24 PM
VenkmanP's Avatar
VenkmanP
It's been a while since I read the corvette fuel injection book, but I think it said it uses everything that is used in closed loop except the O2s.
Old Apr 16, 2006 | 05:27 PM
rickneworleansla
Default testing sensors
Is there a tutorial somewhere or can someone tell me how to test all the sensors used during open loop? Coolant temp sensor, Throttle positioning sensors, etc... I already have a multimeter. Mid america sells this kit http://www.madvet.com/shop?frame=3.882 Is it really necessary?
Old Apr 16, 2006 | 06:30 PM
CFI-EFI's Avatar
CFI-EFI
Tutorial, HERE.
It CAN make things more convenient, but for $90.00 it is easy to do without, at least it is on the earlier C4s.
RACE ON!!!
To Open loop sensors, fuel delivery
