How much torque before rearend goes?
Old Apr 17, 2006 | 04:14 PM
nelson84's Avatar
nelson84
Default How much torque before rearend goes?
I have an 84 vette auto will be puting in a superram and 383.
How much power will the dana 36 handle?
I blew the rear end with the crossfire once already, the superram should twist it good.
Old Apr 17, 2006 | 04:18 PM
vader86's Avatar
vader86
There is no definite limit to how much it can handle, it could go with stock power levels if the conditions were right.
http://temp.corvetteforum.net/c4/vader86/rearaxle.html
Old Apr 17, 2006 | 08:27 PM
Biff Buyer's Avatar
Biff Buyer
they can last a long time or they can bust after a couple hard runs... Just depends...
Old Apr 17, 2006 | 11:25 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
It's all about the hook...one good hook is all it takes...I turned my 36 into chicklets with one hook on street tires and that was with only 303 rwtq...
Old Apr 18, 2006 | 12:11 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
How are these things breaking?
Twisting off pinion shafts at the base of splines? Flexing cases and breaking gear teeth? Cracking cases open?
Old Apr 18, 2006 | 08:46 AM
Pete K's Avatar
Pete K
Every one I have broken, or seen broken, tears the teeth off the spider gears. If you are lucky, disassemble, clean and replace the 4 spiders and the rear is fine. If unlucky, the chicklets get caught between the ring gear and the case. That usually scraps the case.
To How much torque before rearend goes?
