My Single Plane Works!
Old Apr 18, 2006 | 03:50 PM
dave_85's Avatar
dave_85
Default My Single Plane Works!
I just finished my single plane conversion. Started right up. I made the plenum with a band saw, drill press and an air grinder. I had a shop weld it for me. The intake is a Holley EFI single plane. I know, I know but it was cheep on ebay and in the intake shoot out last year it kept up with a Mini Ram on a 383 until about 5800 rpm. The plenum is made out of 3in x 6in tubing welded to a ½ plate. Inside I have solid aluminum under the bolts from top to bottom to transfer the clamping force to the bottom plate and to guide the air into the manifold. No leaks so far. I also have a ¼ section of 6in tube to act as a radius in the rear of the plenum. I used a Moroso billet aluminum water neck and cut it down a ½ in on the top and bottom to fit under the plenum. It so easy to install it’s a joke. I have to get my insurance turned back on and take it for a ride.
Old Apr 18, 2006 | 05:16 PM
Ramanstud's Avatar
Ramanstud
Old Apr 18, 2006 | 06:46 PM
pipe's Avatar
pipe
Do ya have any pics of the bungs welded into the manifold that hold the injectors? who made the fuel rails? It's cool lookin job would like to see more pics of it. Pipe
Old Apr 18, 2006 | 07:55 PM
Googan's Avatar
Googan
So whats the total cost to get this done?
Old Apr 18, 2006 | 08:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dig those setups, looks nice!!
Old Apr 18, 2006 | 08:31 PM
dave_85's Avatar
dave_85
Plenum including welding $125, water neck $65, fuel hose and fittings $50, $16 for the Accel throttle bracket. I got the Holley intake with fuel rails and adj. regulator cheep off ebay but Summit has if for about $550.
The way I look at, I'm going to sell my Edelbrock TPI base and AS&M big tube runners and it pays for the change. That is if I like the way it runs.
Old Apr 18, 2006 | 08:32 PM
dave_85's Avatar
dave_85
No welds, stock Holley EFI intake.
Old Apr 18, 2006 | 08:39 PM
redrose's Avatar
redrose
11 gold stars on a 1-10 scale for that ....even if it doesn't work (although i expect it will work fine) the appearance alone will send the ricers back for new diapers.
details on injector bungs and fuel rails please?
Old Apr 18, 2006 | 08:52 PM
dave_85's Avatar
dave_85
The fuel rails and regulator are Holley 9900-172, the intake comes with the injector bungs cast into the intake Holley 9901-101-1.
Old Apr 18, 2006 | 09:01 PM
DanZ51's Avatar
DanZ51
I have to ask: why appologetic about the Holley single plane? I've been eye-balling this same manifold myself for a similar set up. What "intake shoot out" are you referring too? (Damn, leave the country for a year...I miss everything)
Looks smokin'. Let me know how it performs!
Old Apr 18, 2006 | 09:54 PM
SHINOBI-X's Avatar
SHINOBI-X
LOOKS GOOD! hope it performs as well as it looks, must hear performance results from intake very soon. alot of us are wondering and have questions from the design.
Old Apr 18, 2006 | 10:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice work. Simple, yet effective, and no pain in the but to install
Old Apr 18, 2006 | 10:26 PM
dave_85's Avatar
dave_85
This is how I got here. The car is a 85 4+3 Z51. I have 3.73 rear end, Pro Topline Iron Lighting 180cc heads, Crane 2030 cam, TPIS headers, 165 ECM with my chip, Zt2 wideband O2. I had an Edlebrock base and AS&M runners. With the TPI I had a hard time not spinning the tires out of the hole plus the power really drops off fast above 4800 rpm. I needed to redo the intake gaskets and just hated the idea of messing with the TPI again, although I am getting good at it. I really wanted a Stealth Ram but it looked like too many problems to overcome to get it to fit in the Vette. I saw a couple of guys running single planes on this site and figured it would be a cool winter project. I should have it on the road tomorrow.
Old Apr 18, 2006 | 10:35 PM
dave_85's Avatar
dave_85
http://www.thirdgen.org/techboard/tp...feb-super.html
Old Apr 19, 2006 | 10:45 PM
dave_85's Avatar
dave_85
I scanned it and set the regulator to give me the same BLM’s that I had before the swap. I did a short WOT run. With the TPI my A/F ratio was around 12.7 % with the single plane it’s around 13.4%. Time to burn a new chip.
Old Apr 20, 2006 | 04:05 PM
Vetracr's Avatar
Vetracr
Plaudits for using some creativity and elbow grease to build a trick set up. Keep on wrenching.
Larry
Old Apr 20, 2006 | 04:21 PM
neat's Avatar
neat
What's the P/N for the Holley single plane?
Old Apr 20, 2006 | 04:47 PM
dave_85's Avatar
dave_85
Intake 9901-101-1
Fuel rails and regulator 9900-172
Old Apr 20, 2006 | 06:19 PM
dock351's Avatar
dock351
St. Jude Donor '06
that looks awesome, and I'm impressed with your design and engineering. Can't wait to hear how she runs. this would make a good tech tip, too.
To My Single Plane Works!
