C5 brakes on a C4?
Old Apr 20, 2006 | 04:30 PM
Crazy Cowboy's Avatar
Crazy Cowboy
Premium Supporting Vendor
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default C5 brakes on a C4?
C5 brakes on a C4? Can it be done and if so what, if any, hardware is needed.
Old Apr 20, 2006 | 04:38 PM
Wildcat1's Avatar
Wildcat1
Try the search, there are tons of threads with all the info needed for this.
Old Apr 20, 2006 | 04:51 PM
Crazy Cowboy
Cruise-In V Veteran
Thanks Cat, if you find a link please post it here? I searched a few key terms and really could not find what I was looking for (although I'm sure it's there somewhere). Just trying to save some time if anyone knows or can post a link to a prior info thread. THanks!
Old Apr 20, 2006 | 05:02 PM
Wildcat1's Avatar
Wildcat1
It can be done, a bunch of members have done it. I won't do it cause I like replacing my cracked rotors each year and being lighterweight. The C5 rotors weigh 6lbs more per rotor than the standard C4. Here's a link to the kit, it requires a special bracket. http://www.vbandp.com/detail.aspx?ID=292
Old Apr 20, 2006 | 08:28 PM
Crazy Cowboy
Cruise-In V Veteran
Thanks Brother!!
Old Apr 20, 2006 | 09:10 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You'll need...
#1: You can buy kits from Ecklers or MidAmerica or
#2: Shop around using EBay, GM, etc.
I found the calipers and rotors on E-bay, pads from Hawk, caliper brackets and adaptors from Upfront technologies. The mistake I made: Hawk pads did not come with the anti-rattle parts. Dealer sells them with brake pads as a brake pad kit. I now have replacement pads for next round
To C5 brakes on a C4?
