Best Performance Injectors?
Old Apr 20, 2006 | 11:51 PM
93stroked's Avatar
93stroked
Default Best Performance Injectors?
Hello Everyone I have a 93A4 383 with Edlebrock heads, comp cam, Crower roller rockers (1.6) ,JE pistons,Lunati crank/rods,58mm BBk, Dana 44 3.73.....just to name a few mods....I'm looking for the best set of fuel injectors probably around 30lb. I've read some posts here that say Accel injectors are crap and there recommending Ford #24's, But these seem to be for stock setups does Ford make a higher flowing injector? Thanks for any info.
Old Apr 20, 2006 | 11:55 PM
MrNuke's Avatar
MrNuke
Yes, you can get a set of Ford SVO injectors in higher output. 30lbs or so should be sufficient for your car, unless you are going to go further with it, blower, nitrous, then you'll need more..
Old Apr 21, 2006 | 12:00 AM
vader86's Avatar
vader86
With your combination, I would be calling whomever I got to tune the car, to get their recommendation about injector size. 30's can be too big, even for a 383.
What is the reason you want to change to a larger injector? Is there some specific issue with the ones you have now?
The 24s you see us recommending alot work both for stock and heavily modded setups, another reason why we do that. But those are L98s, and I thought that LT1 came with the 24s already.
Old Apr 21, 2006 | 12:21 AM
93stroked's Avatar
93stroked
Well, the injectors are the stock 24lbs and they have 95k on them, so I just wanted to upgrade....
Old Apr 21, 2006 | 01:27 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
For your setup I would definately reccomend a set of 30 SVO's.
Old Apr 21, 2006 | 05:56 PM
93stroked's Avatar
93stroked
I ordered the #30 SVO flow matched injectors from Fiveo today, thanks for the info......this is the best forum out there
Old May 3, 2006 | 01:27 PM
93stroked's Avatar
93stroked
Default Pressure setting for new 30lb's
Hello everyone I just installed the new injectors and I was wondering if I have to adjust my fuel pressure? Key on engine off goes to 45 then it sits @ 41.
What should the idle and WOT pressure be? Thanks agian Mike
Old May 3, 2006 | 01:28 PM
93stroked's Avatar
93stroked
Old May 3, 2006 | 01:33 PM
93 ragtop's Avatar
93 ragtop
Mike, assuming you already had a custom tune for the mods you have listed, you will need to have it reworked for the additional fuel from the 30lb injectors. I dont believe you could drop your pressure enough to handle that.
Old May 3, 2006 | 02:32 PM
93stroked's Avatar
93stroked
Thanks for the info, I guess i'll be headed there tomorrow
Old May 3, 2006 | 02:34 PM
93stroked's Avatar
93stroked
One more thing, it should be ok to drive around today...say 15 miles today and then it's about 15 miles to the shop?
To Best Performance Injectors?
